Question about Lands Phones
Cable & Wireless CWB200H Speed Dial
Does anyone know how to store a number on this phone which has 3 speed dial buttons and a number of memory stores
  • DonnaBrydon Aug 15, 2008
    Which are the 3 speed dial buttons?
    Once you have selected which button you wish to use how do you end the programming
1. lift the handset.
2.press store
3. pin in number to be phoned.
4. press store
5. press one of quick dial buttons
Posted on Jun 30, 2008
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
Speed dial
1. lift the handset and listen for the dial tone. 2. press the store button 3. dial the number that you wish to store 4. press the store button a second time 5. press one of the numbers on the phone [0-9] and that will become the speed dial number. 6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
Feb 19, 2010 | Southwestern Bell Freedom Phone FM2552
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
How to proram speed dial
Here is the solution:
1) Pick up the handset
2) Press the "Store" button
3) Dial the number that you want to store
4) Press the "Store" button
5) Press one of the Memory button such as M1, M2, etc.
6) hang up the phone (put the handset back to the base)
When you're ready to dial the number, just pick up the handset and press one of the Memory button that you just use to store your desired number.
Best of luck,
KP
Dec 18, 2007 | Sakar Talking Caller-ID Speaker Phone
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Programming the "Memory Dialer"
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Jun 27, 2007 | Northwestern Bell Classic Favorite 52860...
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Lands Phones Logo
637 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
