Question about Casio Exilim EX-S600 Digital Camera
Card Error I got a new Casio EX-S600 and it came with a 2GB memory card but when i insert the memory card it says card error
  • 477 Answers
Try formatting the card from the cameras menu. if that does not work take it back and get it replaced. That sould be covered. Good Luck.
Posted on Mar 30, 2008
When i insert my memory card into my brand new CASIO EX-55O/0 camera,a message comes up and says "card error"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (of which your camera was made before SDHC. You can only use 2GB or less cards). Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 16, 2011 | Casio Exilim EX-S500 Digital Camera
Everytime i turn on my camera, it always says card error".
when is says card error it means cannot read your memory card in the camera either it is corrupted or not properly inserted... check it.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. Thanks
Aug 17, 2010 | Casio Exilim EX-Z57 Digital Camera
I have a Casio EXILIM EX-S10 "Memory Full" Error
Firstly, charge your battery fully. This should solve the switching off. It sounds to me like your card isn't in correctly, or is incompatible, and your internal memory is full. (it usually only stores a few photos for emergencies) Have a look at the type of card you have. If it says SDHC, or is 4GB or larger, it is not compatible with your camera and you need to get a 2GB. If not, it may not be inserted correctly. Push it all the way into the slot and it will click when it's in properly. Then try formatting it. Press review (where you look at the photos) and scroll down to setup- then look for 'format' and press okay. This should sort everything out. You can also copy the photos you've taken in the meantime from the memory to the card by pressing copy in the review menu and scrolling to the right. Hope that helps
Jul 26, 2010 | Casio Exilim Card EX-S100 Digital Camera
New 4gb sd card will not work. card error
Is the slide switch in the unlocked position? Are you formatting it in the camera? Are the card contacts dirty?
Dec 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Card error coming up constantly
there is a chip in the device that lets you to know whats in it. maybe its broked down.
Jun 02, 2009 | Casio Exilim EX-Z55 Digital Camera
Card error
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual:
http://support.casio.com/pdf/001/EXZ60_e.pdf
Apr 28, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera doesn't turn on with video card inserted or shows "error "
try inserting another piece of memory card. and format it. if the problem still persist, i suggest that your camera needs to be brought to the service center.
Dec 05, 2008 | Casio Exilim EX-Z57 Digital Camera
Card error
Casio only recommends Sandisk, Toshiba and Panasonic for memory cards. More than likely you have a card that is bad. Purchase a new card and make sure you format it with your camera before you try and use it.
Nov 25, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio camera card error
It could be either a brand that is not supported or there could be something wrong with your card. Casio only recommends Sandisk, Toshiba and Panasonic memory cards. Try one of those brands and make sure you format it with your camera before trying to save pics to it.
Nov 17, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
237 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
