Question about Apple iMac 233Mhz/333Mhz Power Supply (Rev A) (p/n 661-2081) Power Supply
IMac 233MHz Screen constantly refreshes
  • gonnagitsum Mar 13, 2008
    Thanks for the info but I think it's more hardware as I've not loaded anything in over a year - was sitting in storage for almost a year
  • gonnagitsum Mar 14, 2008
    The screen does turn off and on - will be on an application, the screen will go black, then come back on - does this every couple of minutes - annoying as hell, but doesn't skip a beat running the application. Could be dust, could be the flyback transformer, could be the analogue board but will hope it just needs a good cleaning.
    I've never cracked the case on my iMac but have built a few custom PC's and seen my iMac apart in the shop so it can't be rocket science!
    Problem Solver:
  • 13 Answers
Could be a software problem.
Posted on Mar 13, 2008
  • Anonymous Mar 13, 2008
    Well than in that case I don't think that the screen is refreshing it might be turning off & on!
    I suggest to clean out all the hardware from dust and dry it out in case of moisture.
SOURCE:
Screen ghosting
That is a shop job, checkout main board systems
Mar 04, 2013 | Apple iMac 24" Desktop
Screen is flickering constantly and goes black after a while
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments. As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting. If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate. If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet Hope this helps.
Jan 17, 2013 | Dell Inspiron 1501 PC Notebook
Alright, so, N64 and a very new Polaroid, flat screen television. The console works fine, as does the television, but when we try to play on the N64 with this TV in particular, the screen is flashing...
Check to see if you can change the refresh rate of the television. (Newer screens refresh faster than the old ones, and if it is refreshing faster than the N64 can put out, you will see black flashes)
May 04, 2011 | Nintendo 64 Console
My brand new imac is shutting down while I'm working - it seems that when it gets warm it is shutting down and it needs more than 1 hour to switch on again. Is there any problem with the new imac's and...
Their was a problem of the processor. That's why they are going to shutting down because the processor are overheated. So you need to replace that processor.
May 29, 2010 | Apple iMac 233Mhz/266Mhz/333Mhz Internal...
How to get IMac 10.6 to recognize YTP300 keyboard via UX16
Try turning the I Mac of and on when you do refresh the list try that it should work
Nov 02, 2017 | Apple Computers & Internet
Imac Screen "Flashes" constantly
launch System Preferences.app from /Application/System Preferences.app
select universal access in System Preferences.
Select hearing tab, uncheck "flash the screen when an alert sound occurs" button.
This should solve your problem
Jun 28, 2009 | Apple iMac G5 Desktop
Support
pentium 2? the minimum required for xp is around 233mhz. I would recommend atleast 500 mhz for faster useage. and more than 128mb ram.
Jun 06, 2008 | Intel Pentium II slot 1 233Mhz...
Sony Mavica CD400 -- can't get iMac to see mini disks
Bob: the Mac will never show what is on the disk.....and you don't hgave to finalize either. Do you have Image Capture on your units? If so, all you need to do is connect the camera via USB cable to the computer. The program will come on automatically (the camera has to be on), you can choose to download some or all of the pictures to a folder of your choice. HTH
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Apple iMac 233Mhz/333Mhz Power Supply (Rev A) (p/n 661-2081) Power Supply Logo
46 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
