Question about Acer Aspire 5100 Notebook
Thanks for helping, murpium and poplock, but...
.. could you kindly show us how to get into ACPI, or safe mode, or restart, or anything else, since the keyb and touchpad are all-dead?
what's the magic key you press to enter start-in-safe-mode?
thank you anyway
ftp
  • fix-the-prob Mar 29, 2008
    EngineerGR,
    this strange acer 5100/3000 series common issue - occurring few days after the warranty went out - has the only fix by replacing mo-bo or (even better) trying elsewhere for the next laptop to buy. I did the 2nd, of course, Sony Vaio here now.
    btw, just to be clearer: no other ext usb keyboard nor mouse "fixed-the-prob" so far and mobo isn't forced anyway to see usb devices.
    that's why I guess it could be a usb ports issue, since my acer stopped to work after I've plugged in an usb device (ipod).
    it could be interesting if some skilled mate of us would try to hard "deactivate" usb and look out for what happens then...
    cheers
  • stargirl21 May 21, 2008
    heeellllppp!!! i tried the solution that murpium posted (taking out the battery of acer laptop with frozen keyboard and touchpad) which worked fine. i've been using the laptop for about 2 or 3 weeks with no battery in it, without a problem...until today...the same problem happened again without the battery in it so now i don't know what to do!!!! :cry:
    Novelist:
  • 119 Answers
Dear fix-the-prob Unfortunately there is no magic key to enable you to do this. Computers do not have 20 backup systems like airplanes. Which would be nice but it would cost like one too! You have two options though to solve this,
  1. Firstly either change the laptop’s keyboard (which is a bad solution if the keyboard is fine and the problem is actually the motherboard)
  2. Second is to find any USB keyboard (easy these days) plug it in an USB port at the side of the laptop. The bios is forced to see this keyboard instead of the laptop’s.
Regards Please don’t forget to rate this solution if it was helpful, it keeps us going!
Posted on Mar 28, 2008
  • 3 Answers
In the case of my Acer, this touchpad and keyboard problem was related to ACPI and the battery. In order to get into Windows with your mouse and keyboard fully functional, remove the battery and keep your laptop plugged into the wall. When you get in, everything should be fine (you don't need safe mode for this). Once you're in, go to your Control Panel, go to System. In that pop-up, go to the hardware tab and click Device Manager. In the Device Manager, click the plus sign next to Battery. In there, right click "ACPI-Compliant Battery" or something like that and choose Disable.
Reboot with your battery in place. It should work just fine. Replacing the battery with one from eBay solved the problem on mine. Without ACPI your computer cannot go into standby and doesn't have all those nice power-management features associated with it.
Hope that helps. Your issue might not be ACPI-related. :\
Posted on Apr 27, 2008
  • 47 Answers
Another suggestion would be to re-plug the cable that connects the keyboard to the motherboard
hope this helps
Posted on Apr 10, 2008
2 Suggested Answers
SOURCE:
  • 36 Answers
SOURCE: boot failure
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s132
Posted on Jan 07, 2009
PLEASE HELP TURN OFF SAFE MODE
To get turn off Safe Mode, please try the following.
1. Touch and Hold the Power key.
2. Tap Power off.
3. Once the phone is off, Touch and then Hold the Power key again to restart.
The phone should now be out of Safe Mode.
However, if the Safe Mode is still running after you restart your phone, I would then check to make sure your Volume Down button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, Safe Mode.
If that doesn't work try this...
Use the Status Bar to turn off Safe Mode. Pull down (swipe) the status bar of your Samsung Galaxy S6. Now tap the "Safe Mode" button. This should turn Safe Mode off. Now your phone will automatically restart, so that it boots up out of Safe Mode.
Hope it helps you:-))
https://rankupplabs.com/
Aug 02, 2018 | Computers & Internet
Why does my acer aspire v5 -431/471 freeze and become very slow?
Start in Safe Mode. Open Device Manager and expand Batteries.
Disable the entry "Microsoft ACPI-Compliant Control Method Battery".
Close and restart notebook in normal mode.
Aug 03, 2014 | Acer Aspire V5-431-4689 14 inch Intel...
Cant hear sound off my laptop
There are two possible reasons why your laptop is experiencing from this kind of problem.
1. Hardware problem - you need a technician to fix it.
2. Software issue - you can do it yourself
Here's how to isolate the reason why you are having this issue.
Boot to safe mode.
Restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe mode with networking. Hit enter
Once you are in safe mode, check if the sound works. If yes, then update the sound driver. You can find the sound driver in the website of the computer's manufacturer. Or you can use RadarSync to search the driver and update it without you doing anything at all. I will also scan the other drivers which are outdated.
You can also go back to the normal mode by restarting your computer and go to the device manager. Uninstall the sound driver from there and restart your computer.
I hope this helps!
If you have any questions, please drop me a line.
David
Apr 11, 2013 | HP Pavilion Computers & Internet
A problem detected and windows has been shut down to prevent damage to your comp. I this is first time that u have seen this stop error screen restart pc. If this screen appears again follow these...
This happens when your operating has a problem with it's hardware, e.g or ram etc. Also some windows major files like DLL are gone missing by chance. Try to restart the Pc and press f8 until you get the options to start in safe mode, If safe mode dosn't works and gives the same informaton, try to make a backup of your filesby using the external hard drive, whereby you will need any other computer to make this backup, from your own hard drive. After doing this, you can format the hard drive and load operating system on it, if you know how to do this. You haven't mentioned the operating system you have in your pc, if you have vista or win 7. by pressing f8 key will aslo give you options, e.g..repair, run computer to last known configuration etc. Hope this works, or you can also go online help with service tech.
Sep 01, 2011 | Computers & Internet
I have installed PC Security on Vista. I forgot the password for it and now it is showing Intruder Detection window and not allowing to do anything. I am not even able to do anything of kill the process....
Restart the computer in Safe Mode. To do this start the PC and the moment you hear or see anything start tapping F8. On the screen that comes up choose Safe Mode. Do not choose any other option. Go to Add/Remove or better yet CCleaner if you have it installed and uninstall PC Security. Restart your PC and it will restart in Normal mode.
Nov 10, 2009 | Computers & Internet
Error 65536
Can you say SPYWARE...make your pc get into the safe mode....
Open up the start menu search or run box, and type in msconfig and hit the enter key
Select the Boot tab, and then check the box for "Safe boot" and make sure the radio button below is set to "Minimal".
Once you hit the OK button you'll be asked if you want to Restart now or wait until later. Either way, the next boot will take you into safe mode.
Once you restart, you'll realize that you are in Safe Mode because it not only places that text in the four corners of the screen, but it even opens up the safe mode page from the help file in Vista.
Now you can work on getting rid of that spyware…
Once you are done fixing whatever you were working on, you'll probably want to turn safe mode off and go back to normal mode. Just open up msconfig the same way as above, and then on the Boot tab you'll uncheck the "Safe boot" checkbox.
So now you know, someone is peaking...
Hope this help you my friend, good luck, please leave rating, thank you kindly
Apr 26, 2009 | Computers & Internet
Problem with celeron M compaq notebook
Prior to having this problem were getting any messages stating that your computer was unprotected. What kind of security does your brothers laptop have.
Dec 17, 2008 | HP Compaq Presario C304NR Notebook
Wont boot into safe mode, hold up at loading driver acpi multiprocessor PC
do you have XP bootable CD? If yes goto BIOS settings and select primary booting device CD Drive and save settings and exit. After restarting your system You will be asked to press any key for installing the OS.
Oct 29, 2008 | Microsoft Windows XP Home Edition
Dazed and confused - unknown system restart
First off, take the message at its word: restart the machine, go into the BIOS and disable all power saving. Also, turn off ACPI if it's on.
Jan 28, 2008 | Computers & Internet
Frozen keyboard acer 5100
Does this happen every time you boot?
Have you tried an external keyboard?
Dec 01, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
244 people viewed this question
Ekse
Alun Cox
