I have a 2001 alero that has a squeeky front, passengers side wheel... possibly could be the bearing, how do i stop the squeeking?
The bearing does not make a squeaky sound.What your problem probably is,is the front brake pads are worn down to the warning clips.They have these on there so you don`t wear them down to metal and damage the rotors.Hope this helps.Good luck.
A bearing typically has more of grinding type of rumble rather than a squeek.
Try checking your brakes...the caliper may not be releasing completely. Cleaning them can solve the problem and prevent premature wear.
