Plasma display fault
Panasonic TH-42PX60B Right half of screen is normal pic. LH side to 1/4 width peak white, next 1/4 width is black with 2 red and 1 blue vertical lines about 2mm wide. Any ideas?
  • andrewdwork Mar 12, 2008
    nhjchabghchtybahbbyug
    Was that a solution or a jok?
Nhjchabghchtybahbbyug
Posted on Mar 12, 2008
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
TH-42PX60B black vetical lines
If vertical lines are displayed to plasma displays, the fault should be with COF boards. These units can be located at the bottom side of the screen [in a row]. If its connection to panel become loose, this type of fault can occur, and is my experience. Check all the COF connections first. See whether IC used on each COF is damaged or not. You can't check it by using a multimeter; only can do a visual-test, whether there is any break or small holes on this IC. If you wish to get more details, check the site linked here. It has screen-shots to fault plasma displays. You can note it, and compare to that of your TVs' screen, and make sure about the fault.
google.com/+GopakumarGopalan
Nov 25, 2013 | Panasonic TXNC21BJTUJ C2 Board TNPA3813
Right side of screen blurry with lines-TH-42PX75U
Check the site linked below, and compare the screen shots. It has many kind of defective screen-shots to plasma displays. Compare them to that of yours, and make sure about the faulty board or others. http://electronicshelponline.blogspot.com/
May 20, 2013 | Panasonic Televison & Video
Panasonic viera screen
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 02, 2013 | Televison & Video
When you use a input the screen fuzzes red. It's a Panasonic Plasma TV TH-42PZ85U. It was made in 2008. Started when i was playing a game. It did it a few times and now its permanent. On the Video Inp
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2017 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Half the screen is black - the right side . The left side looks normal. everything else seems fine. It is a panasonic viera TH-42PX60U
Hi there! Your fault seems like the (From the back) Left X-Drive Board. Perhaps you can check for bad cable connections. Be careful not to damage the flexible ribbon cables as they tear easily. These boards are located on the top and bottom of the screen.(2 narrow boards, connected to one another) The narrow ones on the side are the Y-Drive boards and is not the fault. Best Wishes and Good Luck. JUS004
Aug 23, 2009 | LG 50PG25 50 in. Plasma HDTV
TH-50PX60U Panasonic Plasma - Flashing red light (now, reset, apparently) - and, missed what code was. Now, left half of screen blank. Right half normal. I managed to get it back, briefly, and while it...
This is either a logic problem or a connection problem within the display controls. I have sen this with a power suppy problem as well. Since the picture was fine before the outage, it is unlikely to be the panel. Anything else should be covered under the extended warranty.
Dan
Sep 03, 2008 | Panasonic Televison & Video
VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display  panel is defective and you must replace it
Oct 28, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
