Question about TallyGenicom 2280 Matrix Printer
Paper width error on tally genicom 2280+ printer
After loading paper on my tally genicom 2280+ printer, and set to print, it print for 2 minutes, afterwards, it displays paper width error on the screen of the printer, and eventually stop printing, what can i do?
  • 2 more comments
  • Anonymous May 16, 2008
    After i have finished loading paper on my tally genicom 2280+ printer, and set to print, it print for 2 minutes, afterwards, it displays paper width error on the screen of the printer, and eventually stop printing, what can i do
  • Anonymous Nov 13, 2008
    I am getting the same error on both my new Tally printers
  • amit_vijan Feb 14, 2009
    i have tally 2280 printer which gives printhead hot error can anyone help me pls
  • Anonymous Mar 18, 2009
    After loading paper on my tally genicom 2280+ printer, and set toprint, it print for 2 minutes, afterwards, it displays paper widtherror on the screen of the printer, and eventually stop printing, whatcan i do?
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Posted on Jan 28, 2009
    New Friend:
  • 159 Answers
Tray to check the photo sensor on the tractor feeder
if the problem stay tray to install new firm ware
Posted on Mar 12, 2008
The problem that i have is about t2280+ printer showing hardware arlam 002 how can i solve it
Posted on Dec 12, 2008
Hi my Tally printer giving an error Pw Sensor defekt plz advice me
You are seeing the "PW Sensor Defect Error" because the printer is detecting a fault with the Paper Width Sensor.
The Paper Width Sensor is located on the print head carriage and detects the paper edge to prevent printing on the platen.
You can check the follwoing;
  • Ensure the print head cable is not damaged and makes good contact with the printer and print head carriage
  • Ensure the Paper Width Sensor is connected correctly to the print head carriage assembly
  • It may be necessary to replace the Paper Width Sensor
Mar 09, 2011 | TallyGenicom 2280 Matrix Printer
In our office we want the printer tomsupport the paper size 15*12. We create the paper size. but it is not displayed while setting the paper size for printing. Our printer is Tally Genicom 6306
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Jan 08, 2011 | TallyGenicom 6306 Matrix Printer
TALLY GENICOM 2280+ HARWARE ALARM CODE +0016 +131
Unfortunatly not enough of the Hardware Alarm Task Number is included in the description to identify the most likely cause of the problem but some things you can check are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
  • Dec 06, 2010 | TallyGenicom 2280 Matrix Printer
    Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
    problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
    Apr 20, 2010 | Tally T6218 Matrix Printer
    My printer stoped in the midle of print
    The 2280+ is indicating a defect with the paper width sensor, the paper width sensor on the 2280+ is locate on the carriage and detects when you try to print off the paper.
    You may wish to disable the paper width sensor. To continue printing, this can be done in the following way.
    Power the printer on holding down ONLINE
    When the printer displays ASCII80 ASCII136 along the top line of the display release the ONLINE button.
    Press the Button under NEXT (button 4) repeatedly until you see APW
    Press the button under APW
    Press button 3 to change this to OFF
    Press SET
    Place the printer ONLINE to exit the menu.
    This will disable the Paper Width sensor which should resolve the issue with the message being seen. You can then get an engineer to look at the paper width sensor to see why this is not working.
    Aug 05, 2009 | TallyGenicom 2280 Matrix Printer
    "check ribbon " error is comming on my tally 2280+ serialprinter
    The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
    I have fitted a (code 062471) and now it is printing fine again.
    a google search reports both these codes as compatible but they are quite clearly, not.
    Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
    Tally t2250problom
    go in setup ,check paper ,inside size ,width,
    select one that u want and save it & test
    Dec 06, 2007 | Tally T2250 Matrix Printer
    TallyGenicom 2280 Matrix Printer Logo
    2,029 people viewed this question
    Top TallyGenicom Office Equipment & Supplies Experts
    Kolbrun...
    none
    Raj Patel
    Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
