Question about Canon i80 InkJet Printer
Service error 5C00
My Canon i80 has this message now after I've refilled the ink tanks and put them back in. I used to do the same thing and they worked well. Now, it gives off a rattling sound before the light blink orange and green alternately and I get this message:
"Service error 5C00.
Cancel printing and turn the printer off and then back on.
If this doesn't clear the error, see the printer manual for more detail.
One or more ink tanks may have been replaced.
If you have replaced them with new ones, reset the ink counter on the Maintenance tab of the printer driver."
Tried doing so, not working. What's the best to do?
Girl08
  • summerbreez Jun 03, 2008
    Service error 5C00.
    I Cancel printing and turn the printer off and then back on.
    This doesn't clear the error, I checked the printer manual for more detail but not help.
    I checked the ink tank that may have been replaced.
    I replaced them with new ones, reset the ink counter on the Maintenance tab of the printer driver."
    Problem Solver:
  • 10 Answers
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Posted on Mar 13, 2008
I get Service error 5C00 for my Cannon i80
Canon USA has a down loadable file for the manual.
Here is the link.
Here is what is being said of this error on the forums:
Fixing this error is much easier as it looks. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad
Apr 28, 2010 | Canon i80 InkJet Printer
I am getting a 5c00 error message on my pixma ip90v - ive changed the ink tanks and made sure they are correctly installed. ive even unplugged the printer from pc and powersource for 10 minutes but still...
ok so its strange that u would need help with a $30 printer but that being said try below
It's a purge unit(QM2-2024). Either tiny jammed piece of paper, or the gear is out. New part is going to be at least 50 bucks, then labor. Canon iP90 Service Error Message 5C00
Jan 02, 2018 | Office Equipment & Supplies
MY PRINTER
i AM GETTING 5C00 ERROR
Aug 27, 2008 | Canon i80 InkJet Printer
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Misreads ink tanks: says full ones are empty and there are 2 cyans, etc.
I had the same problem -- error message saying two cyan print tanks installed. Nothing helped (including disconnecting power cord). Then found I had an older cyan print tank still in its pack on hand, Installed that. No further problems. Assume this means print tank giving error is part of a faulty batch so am returning to retailer for refund from Canon.
Oct 24, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on. If the problem remains, contact a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope it helps
Oct 03, 2006 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
890 people viewed this question
old marine
old marine
