Question about Samsung SYNC SGH-A707 Cellular Phone
Cant setup any jar file
I cant setup any jar files like themes or games i download from the net
  • 1 more comment
  • Anonymous Jun 15, 2008
    plzzz help....
  • Anonymous Jul 22, 2008
    I have the same problem as well. I can move it onto my phone but it says unsuported file type. I dont know what kinda of files the games that work are. Someone know anything?
  • Anonymous Jul 23, 2008
    jar file doesnot work in my cell. what sud i do??? arn;t there any solutions??
I have a samsung a707 and i want to download and play java games,and im being told that i have t download .jar/.jad file first.And i would like to know jus how to go about getting those files for my phone and how to get it installed
Posted on Nov 24, 2008
Go here:
http://www.sinkintosync.com/
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000# If your phone says wrong password, turn your phone off and put in an unaccepted Sim Card into the phone (A sim card from another Service Provider) and then start the process over again. If it says wrong password even with the wrong Sim card, then you have reached your second attempt, Do NOT try it again. Instead, go to Ebay and purchase an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now that you know your phone's unlock code, (00000000) you can use the following codes to unlock individual locks on your phone (Where you see the word Code you will put in your new unlock code, which is now 00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
Warning: This phone gives you 3 attempts to enter the correct unlock information. If it fails on the 3rd attempt, your phone will say phone freeze and you will not be able to unlock your phone by entering a code. You will then have to have it unlocked via a cable and if you do this, make sure that the unlock service you are using can unlock phone freeze before you buy it. There are several different options on Ebay if you do a search for "unlock A707"
Posted on Oct 23, 2008
Same Problem
Posted on Jul 22, 2008
SOURCE:
I am using Samsung L700 last 2 Years. I am using only your hanset default theme, because not aviable any link in internet to download any type of theme SAMSUNG L700. Plzcheck. Regards Avadhesh...
It's not possible to change or install new themes in the Samsung L700...as you would see, there is no "themes" or "change skin" in the entire of the settings menu...
SAMSUNG locks the use of games installed by downloading it through the net on your PC and transferring to your L700...it says "FILE NOT SUPPORTED"...but it does support .jar files...we can break this...just do the following...
to install Java games on the Samsung L700 without any software or drivers
In the phone Menu select 'Settings'
Then select 'Phone settings'
Then 'USB settings'
And choose 'Ask on connection'
Plug the Phone in to the PC with the USB cable
On the phone select 'Media player'
On the PC wait until it detects the phone and select 'Open the device to view files'
Open the folder 'Phone'
You should see the folders: images, Other files, Sounds, Videos
Create a new folder and name it 'Games'
Put any game you want to install in that 'Games' folder
Two things need to made sure of when copying over the games. Firstly make sure you have the *.jar and *.jad files for each game, if you don't have the *.jad file, you can download a jad creator pretty easily, just type it in Google.
Secondly each game has to be in it's own folder, if you just dump all the *.jar and *.jad files directly into the 'Games' folder only the first game installed will work (Poorly too).
Unplug the phone
Now on the phone dial the code: *#6984125*#
Select 'Internals' (Number 4)
It will ask for a master key it is: *#9072641*#
Select 'Storage settings' (Number 7)
Update Java DB (Number 2)
Turn the phone off
Turn it back on
The games should now be installed with no problems unless there r other problems such as resolution,etc...
There is a website that offers wallpaper for the Samsung L700: http://www.mobileheart.com/cell-phone-wallpapers/1544-Samsung-L700-Wallpapers.aspx
Feb 05, 2011 | Computers & Internet
I have samsung star nxt gt s 5233s tell me that where i found the themes and games for my mobile
any jar games or app can be installed and used in ur phone. get te jar file . download minicommander app thro ur mob gprs and install it . download jad maker and create jad files and then install using minicommander . try googling it
Sep 09, 2010 | Samsung Cell Phones
How can i install themes in my samsung sgh l700?
download any jar games from any free sites and convert it 2 .jad using jar 2 jad converter , then copy it to your phone and install it.
for themes i'm still of pursuit. OR: You go to www.mobile9.com from zedge.net ,waptrick.com www.getjar.com
Aug 17, 2010 | Samsung Cell Phones
S3310 supports .jar file
Yes your mobile supports .jar files
www.getjar.com/ java jar application website
jar downlaod
Sony Ericsson G502
Features Messaging
SMS, MMS, Email, Push Email Browser WAP 2.0/HTML (NetFront 3.4), RSS reader Radio Stereo FM radio with RDS Games 3D games + downloadable Colors Champagne Black, Brilliant Hazel, Celerity Red GPS No Java Yes, MIDP 2.0 - MP3/MP4 player
- Google Maps
- TrackID music recognition
- Picture editor/blogging
- Organizer
- Voice memo/dial
Apr 02, 2010 | Sony Ericsson G502 Cellular Phone
How to install themes and games in sgh-l700?
download the themes and games,connect the mobile through pc suite,copy the stuff and directly run on the mobile.
Dec 06, 2009 | Samsung SGH-L700 Cell Phone
Unable to install games in samsung s3310 metro mobile
move to this links...
to install games...(.jar and .jad)
http://3310metro.blogspot.com/
to download games:
http://3310goodies.blogspot.com/
to install themes..
http://samsung3310.tk/
i tried all and iam enjoying with my 3310 with live themes,games and lot of stuffs..cmon lets play
"dont forget to rate solution"
Jul 25, 2009 | Sony Ericsson G502 Cellular Phone
How i install the themes, games in samsung sgh e251 by pc
there was not themes for samsung but you can install games ans application in one condition that you have the jar and jad fils : search in internet ( free downlod java games jar/jad ) and install the jad from yor phone.and that's it
Jan 09, 2009 | Samsung SGH-E251 Mobile Phone - Black
Cannot download games to my mobile
for installing games type the code *#9998*4678255# and
u can install games for 24hrs. to install after that
type the code again and is activated.first transfer
jar & jad file of the game to ur mobile and it will be
stored in the 'other files'. now go 2 jad file and open
it and install game option appears. so do it and game is
installed.
Dec 07, 2008 | Samsung SGH-E840 Smartphone
Samsung SYNC SGH-A707 Cellular Phone Logo
418 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
