Question about HP LaserJet 1022 Printer
Hp laserjet 1022
Hello sir my printer cannot working
why because when i give printing it says "the printer spooler service cannot running"
what's u r answer sir plz send the details urgent
  • 2 more comments
  • butty70 Dec 08, 2008
    printer spooler is not running
  • Anonymous Dec 20, 2008
    Dear sir
    our printer working normal LDE but paper not recvice
  • khgiese Apr 28, 2009
    The problem is with the driver not the print spooler. We have an office where multiple printers are install. Some local and some network based. The only printer we have a problem with is the HP1022. The drivers that HP offers for vista are junk at best. When confronted by documented examples both HP and MS prefer to use finger pointing to avoid solving the problem. HP says it is a MS problem. and MS says it is a HP problem. From where I stand it is a HP driver issue. This is most likely to happen when you try to send a .pdf file to the hp 1022 printer. We were able to tweak it for a short time by using the Windows XP drivers and forcing Vista to load them. This worked for a couple mionths.
    Problem Solver:
  • 6 Answers
It sounds like an issue with the spooler service on Windows.
You will have to download the tool kit to run it. It states for windows server 2003 but will also work on xp Her is the link fo rthe download:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9D467A69-57FF-4AE7-96EE-B18C4790CFFD&displaylang=en
here is a link with direction for running it on xp
http://www.windowsreference.com/windows-xp/how-to-clean-print-spooler-in-windows-xp2003/
When you run it it will ask you if you are sure you want to delete spooler files. clcik yes. When it asks if you want to delete USB monitor click on no.
Thisis the fix for the print spooler issue after you run the cleanspl.exetool and wipe out all the ports. You have to add back in the USB portmanually.
Run regedit. Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Print/Monitors.Look for a USB Monitor entry. Before doing anything else, backup theregistry entry by right clicking on "Monitors" and selecting "Export".Give it a name and locaction so that you can put it back if you haveproblems later. If "USB Monitor" is not there, add it by right-clickingon Monitors, New, Key. Name the new key "USB Monitor". Once added,right click on the new key and select New, String Value. Name the newvalue "Driver". In the right portion of regedit, right click on the new"Driver" value and select "Modify". Make the value data "usbmon.dll".If there is an "HPUMON" entry (or the like), delete it. Disconnect theUSB cable to the printer. Run the "scrubber" or clean utility, rebootthe machine. Reconnect the printer and install the driver software permanufacturer instuction. This fixed my problem. Good luck!
Posted on Feb 24, 2009
My printer is not working. Error message is the printer spooler service cannot run
Posted on Nov 24, 2008
    Genius:
  • 3,587 Answers
Hmmm..you may need new drivers..get em here
Posted on Mar 12, 2008
My printer cannot working why because when i give printing it says "the printer spooler service cannot running" tell me why >>> Windows XP professtional serveice Pack 2
Posted on Sep 18, 2008
SOURCE:
My printer is telling me that its not conntcetd to my computer. When I try to reinstall it saying that the Prnter spooler is not responding. Help!!!
For you to print anything from windows you must the print spooler service running. You will find it under control panel, administrative tools, services. In the list under services you will fing the entry called print spooler. It will have stopped so click on start and exit the program. If it does not start then you have another problem with windows and that would need corrected first.
Hope the above works. Oh its the same for XP, Vista and Windows 7.
May 26, 2011 | HP LaserJet 1022 Printer
Hello, I have Dell Latitude D630 running on windows 7 (64 bit), I have a adobe reader ver . 9.3.4, and an HP J6413 All in one print scan fax. The issue as above seems to be larger pdf files, it start to...
pls check how much size file you are giving to print if the file range is too high in mega bytes it will take long time to print and cancel but the same print u r printing in a simple printer it prints in much more speed so pls check installed driver and spooler service
Sep 16, 2010 | HP LaserJet 1022 Printer
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Spooler system is not running in 1020 laserjethp printer
start button
run
type services.msc
select print spooler
right click and select start
select properties and make sure it is set for automatic
Sep 11, 2009 | HP Hewlett Packard LaserJet 1022 Printer
The printing spooler service is not running.
Go to the control panel. Select printers and right click on your printer. Select properties and turn print spooling on.
Aug 08, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Trying to install a print hp 1022 to my laptop which uses vista
Go www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Jan 18, 2009 | HP LaserJet 1022 Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP LaserJet 1022 Printer Logo
898 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
