When the machine is draining the pipes shakes or tremble from the machine throughout the house.
    Sergeant:
  • 351 Answers
It sounds like water hammer in the house pipes.try turning down the taps to reduce water pressure.hope this helps
Posted on Mar 12, 2008
Frigidaire FAC107S1 water drains into the house
One: The drain hose has come out of the house plumbing drain pipe or Two: The house drain pipe is plugged up.
Sep 17, 2015 | Frigidaire Washing Machines
Drain pipe in maytag washer lav3600aww
Best I remember there are two hoses that make up the drain, one goes from the tub to the pump the other goes from the pump to the house drain. You should have got a 6-8 foot section of corrigated drain pipe, this goes to the house, bends around on one end and into the house drain. the other end goes to the machine, you may have to lay down to attach it, I cant remember which side that pump is on, but it should be easily identified
Jan 12, 2013 | Maytag Washing Machines
White smoke from terios 2000 exhaust pipe, manual gear
It sounds like you have overfilled the crankcase, recheck the level.
Jun 07, 2012 | Daihatsu Terios Cars & Trucks
I have an old home that has a very space drain pipe. I bought a new Maytag top load washing machine. The drain pipe is too large for the drain pipe. 2 plumbers have told me the drain pipe will have to...
Whirlpool now own Maytag and with a W/P top load machine there is an adaptor which reduces the diameter of the drain hose. Not knowing the diameters of your drain hose, or the plumbing of your house, I can't say for sure that this is a remedy. However it's worth trying. Contact a Whirlpool stockist and see if the adaptor is the correct size for your new Maytag. Or you may be able to drain the new machine into a laundry tub which then flows into the house drain. This is a normal way of 'taking up the slack'.
I'm surprised your plumbers didn't suggest it.
Good luck Nomess
Nov 10, 2010 | Washing Machines
Is it possible to slow down or reduce the rate at which water drains out of the washing machine? My drain line is restricted and if the load is more than "Small", it drains too quickly and starts...
There is no flow adjustment on the drain on any washing machine, I had a similar problem on my old washing machine, I discovered the problem was the waste water pipe in my house was clogged with scum from detergent residue, I poured liquid plumber where the washing machine drain hose goes into the waste pipe in the house waited for 1/2 hour, then filled the washing machine with hot water, reinserted the drain hose, and wrapped it up with duct tape to prevent further leaks, and the force of hot water uncloged the pipe, .Problem solved
Nov 08, 2010 | GE WHRE5260E Top Load Washer
Would like to know the correct way to have the drain hose from washing machine to drain under house
It must be drained into a sewer line. If drained under the house such as a crawl space on the ground you will receive mildew throughout your whole house ruining clothes, leather products, & your health
May 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My frigadaire gallery is not draining but leaking from bottom at end of cycle and my house smells so bad I'm not sure I can stay here tonight. I have cleaned sinks, throughout house (really old house...
TURN IT OFF ASAP.
use a jack and lift the bottom up
get under it and take a picture of it with good lighting
send the picture to me
This can be resolved within the hour if done now
Oct 11, 2009 | Frigidaire GLWS1349A Top Load Washer
Shakes / trembles when applying brakes
need to have your rotors turned
Mar 19, 2009 | 2001 Lexus LS 430
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Drain and vent
vent pipe in the house?sounds like a plumbing issue in the house. unless your drain hose is to far down the drain pipe.
Apr 14, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
