Question about HP LaserJet 2200dn Printer
Dirty printout and paper jams
My laserjet 2200dtn produces dirty-looking printouts because of repeating horizontal lines and words printed about 1 to 1.5 inches apart. If I have to get the head/rollers cleaned, will it be easy to do it myself?
Also, it experiences frequent paper jams because paper feeds more than 1 at a time. How do I prevent this? What do I need to fix?
Thank you very much for whatever help you can extend on this frustrating exprience.
Hazel
  • Anonymous Jul 16, 2008
    I have a HP Laserjet 2200dn printer that keeps getting jammed. Is there anyway for me to troubleshoot it other than purchasing a maintenance kit?
    Please assist.
    Thanks
  • 4 Answers
Hi Hazel,
Sounds like it needs a maintenance kit. This will include a fuser, which should resolve the problem of the repeated horizontal lines and ghosted words. It will also cause more frequent paper jams when it needs maintenance.
A manual for installing a maintenance kit can be found online but sometimes will come with the kit. Google it anyway as it will give you an idea of the work involved.
Hope this helps!
Posted on May 06, 2008
6ya staff
SOURCE:
My hp3600n makes a grinding sound at start and the printout always has gray verticle smudges on it
If you run the PQ troubleshooting pages you will likely find that your black cartridge is faulty. Sounds like the drum is dragging.
Aug 02, 2015 | HP LaserJet 3600n Printer
Why are the colors on printouts not overlapping?
You probably need to run an alignment procedure. See the link below.
Align Print Heads On An HP Laserjet 1600
Sep 04, 2014 | HP Color LaserJet 1600
I get big horizontal bands across my printouts
If you are sure that the paper type chosen is correct for the paper that you are using, then it is probably coming from the print heads which are either dirty, misaligned or defective. Try cleaning the print heads as your first step and see if this improves.
Jan 27, 2014 | Canon i860 InkJet Photo Printer
The first 6mm is the printout a good quality, the next 48mm is the printout light and the rest is good quality
Read this
http://printertechs.com/tech/print-defects/fadingprint.php
Most likely something is wrong with the imaging belt - it's dirty in that region. Try to clean it. Also check the fuser.
Aug 22, 2011 | HP LaserJet M5035 MFP Printer
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Paper LED blinking
Try feeding using bypass, probally worn/dirty/broke paper cassette paper feed roller having trouble feeding the paper in.
Sep 30, 2007 | HP LaserJet 4L Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP LaserJet 2200dn Printer Logo
249 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
