Question about Fisher Paykel EcoSmart GWL15
Fisher & paykel LW035-K
My machine will fill the try to start and dies i get fult code ooxoxoxx i have checked out of balance switct and it's good but i have no manual any ideas
    Sergeant:
  • 351 Answers
Is the bowl floating freely,when full of water you should be able to move it freely with no clothes in it.the clutch may be stuck.or it may be a motor fault.check wiring etc,but you will need a rotor posistion sensor tester to find out.sorry i cant be of more help
Posted on Mar 12, 2008
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel gw712 will not spin
That is fault code 43
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Apr 06, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel GW708U Smart Drive Excellence 7.5kg Washing Machine. What is fault code 43?
disconnected.
Action:
if suspect.
Action:
Jun 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
May 30, 2010 | Fisher and Paykel Washing Machines
Macchine won't fill with water normally
sounds like out of balance switch is faulty please reply if u need help to test.please turn power off b4 working on it.do not want any accidents
Mar 15, 2010 | Fisher and Paykel Washing Machines
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
151 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
