Pc problems trying to formatt my pc ,, it gets to 35% of the formatt then it stops and tells me unexpected end of file if problem persists contack acerinc surport center ,,, now i have tryed this 5-6 times and keepgetting the samething can you help
    Sergeant:
  • 349 Answers
Download the disc utility from the hard drive makers website put it on a floppy ,reboot with it & run it ,it may recover your hard drive
good luck
Terry
Posted on Mar 12, 2008
  • 35 Answers
Maybe your harddisk have many badsectors on it and it cant be formatted, you better replace your harddisk with a new one.
SOURCE:
55.00.00 DC Controller error
Basically The engine is not communicating with the
formatter.
1. Turn the device off and then on.
2. Verify that the flat ribbon cable between
the ECU and the formatter PCA is
connected correctly.[do extra care while removing from board easily crack at ends]
3. If the message persists, replace the
ECU[check on board and track,component damaged-burned its fixable].
If the message still persists,replace the formatter.{before replacing it can be fixable by hot oven/hot plate method }
inquiry send on http://electronicdoctor.weebly.com
0740d731-eaf6-439f-a99c-b738dfa73141.jpg formatter
156d8d89-0eee-4c56-aad5-db018e3e9d12.jpg ecu
Apr 03, 2014 | HP LaserJet P3005n Printer
Hp laserjet 1536dnf error 79
Error 79
Software/drivers, Memory PCA's, Font-Macro-Personality Cartridges, option I/O Cards. Defective toner cartridge in the Laserjet 4 Plus only. Remove any accessories (font cartridges, memory PCA's, SIMMs, etc.) plugged into the formatter card and try again. If the problem persists and is application specific, verify proper setup with application vendor.
Defective Formatter PCA - Replace with known operational board and try again.
Firmware Update - The configuration page lists the firmware version of the product. Depending on the model, a firmware
DIMM may need replacing or a flash update. On flash-memory-based products, you can update the firmware code by downloading the latest flash executable file for the product and running the program according to the readme instructions posted with the update file. If the firmware should become corrupted or fail (usually because of an interruption when attempting to update the firmware), the product will no longer function. In this case, a firmware recovery DIMM is available.
Reseat DIMM, then Formatter - Replace or flash DIMM then formatter
Can this also be?
Jan 03, 2012 | HP Laserjet M2727nf Multifunction Printer
Can't add or delete files from PNY 8GB Flash Drive
Hello and Welcome to FixYa!
Try formatting the drive using the option available in Microsoft Windows (before that try back up the important data on that drive), if the problem still persists, try using Forced USB formatter Utility, do tell us with the results. Hoping to hear from you soon.
Concerned.
May 08, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
File will not open - ?Unexpected end-of-file encountered?
I had this problem also. Found software from MarkzTools to recover Quark files. You may also want to try having someone with Quark 7 see if they can open the file.
Nov 16, 2009 | QuarkXPress 6.5
When uploading the audio files from any folder
Why don’t you try another usb cable? Or you could try transferring via Bluetooth as well. From the message, 'unexpected error has occurred in communication' you can see that the device providing the communication between phone and PC, i.e. cable is not functioning well. That is why even when you switch from port to port the problem persists.
Sep 15, 2009 | Olympus VN-4100PC Digital Voice Recorder
Was trying to send a fax - now it says Error 70 turn off and back on - have done this 5 times.
It can be a defective fax module or formatter, but most likely, it is a software issue.
Make sure you have the latest firmware.
When/if firmware is the latest version and problem persists, go to Menu -> Service -> Restore Defaults.
If problem persists, it might be a good idea to try a different land line, if you have one available, before purchasing new hardware.
Please note you need a different board depending on which region of the world you live in. I'm assuming North America here.
The fax module for the 2840, is about $27.31.
Part information:
Q3977-60011 - PC Board (Interface) : Line interface unit (LIU) PC board - Telephone interface board for the printer.
If the problem is in the formatter (main board), the price goes up to $405.65. Please not, that the LIU (fax module) is included in this.
Part information:
Q3948-69006 - Formatter / LIU assembly (for North America) - Includes the formatter PC board, the line interface unit (LIU) PC board, and the metal card cage.
Jul 15, 2009 | HP LaserJet 2840 Printer
Mac OS X 10.5 iDisk error -35
Give your mac a few moments to wake up before you try to connect iDisk.
If this didn't solve your problem
1. From the Apple menu, choose Log Out.
2. Log back in.
3. Try to connect to your iDisk.
4. If the issue persists, restart your computer.
You should now be able to connect to your iDisk. However, if the issue persists, follow
these additional steps:
1. Open System Preferences.
2. Click MobileMe.
3. Click Sign Out. Note: This will unregister your computer from syncing with MobileMe, and disable iDisk Syncing if it is enabled.
4. Retype your MobileMe account name and password.
5. Connect to your iDisk.
Aug 27, 2008 | Apple Mac OS X 10.4
Operating system installtion problem
First try to replace you memory module(s) (RAM) should you be using more than one ensure that they are both of the same frequency then when installing windows xp at the setup menu where it asks about partitions delete any present partition and formatt a new partition with the NTFS (do not use the quick formatt, use the more thorough formatt). thereafter you windows will be installed and you shouldnt have any further problems.
Jun 07, 2008 | Mercury PVCLE266 Motherboard
Not able to install nero .....get a msg at the end of installation........CRC failed in Nero\Nerodeu.txt Unexpected end of archive
TRY ANOTHER NERO VERSION.....
........CRC failed in Nero\Nerodeu.txt CAN BE DUE TO FILES CURREPTED,,,,,....
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 20, 2007 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Open Questions:
Computers & Internet Logo
42 people viewed this question
Ekse
Marvin
Marvin
