Im looking for emergency back up systems to down load on to a disc
    Problem Solver:
  • 15 Answers
Try Norton Ghost backup utility. It allows you to backup all your information and later burn it into a C or DVD
Posted on Mar 12, 2008
I have a Pioneer AVIC D3X im get a error 2 when i put in a cd
Dirty, Clean disc, Scratched disc, Replace disc, The disc is loaded upside down, Check that the disc is loaded correctly.
Mar 26, 2012 | Pioneer AVIC-D3 Car DVD Player
When im loading a project, it shows operation failed
Did you try to scan your disc for bad sectors? Look in the manual and it will show you how to do a surface scan.
Dec 13, 2010 | Roland Vs-2000CD Digital Studio...
Im currently running win xp system and im trying to load up a Technika TKNM110 wireless mouse so i can use my laptop when im admitted into hospital next month for a replacement shoulder. The laptop keeps...
If the mouse did not come with an installation disc, and you don't have the XP disc I would check with either Microsoft or the Manufactures website to see if you can download and install the driver from there.
Aug 15, 2010 | Computers & Internet
Windows not loading
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 05, 2010 | Computers & Internet
My powerbook is not dislaying the login window it hangs at the loading screen with the apple sign im using mac os x 10.3.9 how can i fix this problem . . . . . . ?
Try holding down the SHIFT key (either one) while you power on your machine. This is Safe Mode. Will it boot in safe mode?
*Disclaimer: There is a small risk of losing important files, such as your pix and music, when reinstalling the operating system (directions below). You should have backups of your important files on CDs, DVDs or an external Firewire hard drive).*
Do you have your system discs? The discs or disc that came with your computer? Or do you have an OS X disc that you bought? If so, put the disc in the drive (Hold down the mouse button and turn on your machine. That will eject any disc that might be in the machine.Then you can put the system disc in.)
Turn your PowerBook off (hold down power button for about 10 seconds until it turns off) then back on again. Hold down the C key to boot from the CD/DVD. Reinstall OS X. This will not erase your pictures, documents, music, etc. *But don't select "Erase and install" from the Options button. That would erase everything. You may have to choose the "Archive and Install" option This *won't* erase your pix, music, etc.
Reinstalling the operating system is a good way to fix problems where Macs hang when loading. I'd suggest upgrading to 10.4 if you have at least 256 Megabytes (click Apple menu, "About this Mac").
Link to buy 10.4 on eBay if you choose:
Apr 28, 2010 | Apple PowerBook G4 Mac Notebook
My iphone doesnot turn on even i press the top botton.
well mine as well, itried down loading the software n im stuck with just emergency calls
Jan 13, 2010 | Apple iPhone Smartphone
How to change back brakes 1999 ford windstar, back brakes are grinding, brake light on
does it have rear disc brakes or drum brakes, if disc brakes should be changed just like the front and you might have an emergency brake shoe inside the rotor that they call a halo shoe, if it is drum brakes take off the adjusting spring and the return spring remove the brake adjuster,the the brake bar then remove the brake shoe hold down spring by holding the pin from the back and pushing and turning the spring to remove from the pin, you might have to remove the the emergency brake bar from one shoe by removing the horseshoe clip from the pin on the shoe if you have problems putting it back together look at the other side that you have not torn down yet.
Aug 12, 2009 | 1999 Ford Windstar
Disc read error frequently with certain games
Just a disc error, the disc may look fine but it maye of been copyed in correctly im affraid, just take it back for a exchange
Feb 21, 2009 | Sony PlayStation 2 (PS2) Console
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
Aug 20, 2008 | Samsung HT-WP38 System
Computers & Internet Logo
David Payne
David Payne
