Question about Garmin Rino 120 2-Way Radio
Broke rino i have a brand new rino 120 and it just vibrates and shows a blank lit up screen??
  • kaneff Sep 01, 2008
    When I turn the gps on, just a black screen and vibrates - can't see screen
  • kaneff May 11, 2010
    what is a batteripolen?
    Problem Solver:
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Posted on Aug 09, 2008
SOURCE:
Blank screen when powered up
Other than a major failure, the primary cause would be a bad or poorly charged battery.
Mar 13, 2014 | Garmin Rino 120 2-Way Radio
Want to use my rhino 120 with military maps
It can show this by going into the the menu [second icon] setup map, orientation/ grid setup. Change Lon/Lat Grid to On.
Apr 19, 2009 | Garmin Rino 120 2-Way Radio
BRAND NEW WII-HAVE SOUND BUT NO PICTURE
When you turn the Wii on, and the light goes from red or orange to green, press A a few times (this would be to get through the warning/safety screen) then wait a minute. Then when you wave your remote about, you will feel it vibrating as it goes over the channel icons on the wii menu screen. Plus a blue light will be lit at the bottom of the remote to denote player 1.
If all of this happens, it is just a lead or TV input issue. If these things do NOT happen, the Wii is broke and needs fixing by Nintendo!
Also, check the refresh rate on your television an make set to be compatible. That may also cause a picture not to show up.
Dec 25, 2008 | Nintendo Wii Console
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
http://www8.garmin.com/aboutGPS/waas.html
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Oct 02, 2008 | Garmin Rino 120 2-Way Radio
LED does not work
you have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Robert
Sep 20, 2008 | Garmin Rino 120 2-Way Radio
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
Sep 01, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 Send note
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at [email protected]
Pat
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
210 people viewed this question
Top Garmin Radio Communications Experts
Ken Williams
Ken Williams
eradiostore
eradiostore
 mason
mason
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
