Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Drain is clogged
The washing machine has stopped and it says : drain blockage. No water is coming from the hose. The hose is not blocked. Can I fix it myself if there is a piece fabric stock somewhere?
  • Anonymous Mar 15, 2008
    drain blocked comes on but drain pipe is clear.
    What is the white plastic cover?
  • barborka Mar 16, 2008
    Thank you a bunch. That fixed it !!!!
    Sergeant:
  • 351 Answers
Check the filter normally at the bottom corner,you may have somthing stuck in the sump hose to the pump.its normally easy to fix you just have to follow the hose until you find the blockage.does the pump start up because it still could be faulty.hope this helps.
Posted on Mar 12, 2008
Clogged drain pipe on A8200 may tag washer
always come out the back of machine someplace
Sep 30, 2017 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Washing machine not draining water
Hi.
Disconnect power, then move the machine forward and check the drain hose at the back of the machine. Check if the hose is kinked or blocked and check that the hose height setting is as from manual. If the hose elbow is set at incorrect height the water will be siphoned back inside the tub.
Access the drain pump filter (this is located behind front-bottom access trim or door ). If there is blockage in there the water will not be drain completely. Remove trim, unscrew the cap and be prepared to collect water. Ensure that power is off. Remove any blockage in there.
lean or replace the pressure switch and the rubber hose connected to the pressure switch. This device detects water level and stops drain when there is no more water.
If all that does not help, then the drain pump itself must be tested. In some rare case the main control module may be defective. Test all the rest first.
The problem is usually given by blockage, drain hose or by pressure switch.
Regards.
Ginko
Apr 28, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
I have a Roper washing machine and it will not drain the water?
Most common causes for a machine that won't drain are:
  1. Clogged drain tube
  2. Clogged drain hose
  3. Clogged drain pump
To diagnose, remove the drain hose from the drain tube and look for water in the tube. A clog will force water back into the machine. If this is clear, some debris could have worked it's way into the drain hose itself. Check this by removing the hose and inspect for a blockage. If both are fine, the problem is most likely in the drain pump. Many times, a piece of paper left in a pocket will work it's way into the drain pump and get lodged.
Mar 31, 2011 | Roper RAS8445KQ Top Load Washer
Washing machine error came up when trying to drain, so used tube to empty water out of machine and cleaned pump.this seamed to work as error sign didnt come up and machine started to work again but when it...
Something has clogged the drain hose or pump & caused the internal drain hose to split by replacing the hose you will clear the blockage the pump also may need to be replaced also.
Feb 21, 2011 | Zanussi Washing Machines
The washing machine is not draining the water away, so i can not get my washing out
It must be the drainage hose, the water cant go anywhere else. The majority of the drainage hose is out of view, unless you've taken the whole thing apart, so it must be blocked.
Hopefully, it will be under warrenty, or you're looking at arounf £70 for someone to come out and fix it.
In the future, every three months or so, put your washing machine on the hottest cycle with clear vinager, and a dash of bleach; this will help unblock any potential blockages.
  1. step 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. Step 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Step 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Step 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. Step 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool Washing Machines
I have a hmwm 6000 washing machine and i suspect the pump is blocked as it won't drain water. How do I get to the pump to unblock it?
Aug 30, 2009 | Washing Machines
Water not draining after the wash cycle
Sounds like either you have a blockage in the drain pump or the drain hose is blocked.
The washing machine will run the drain pump for about 2 to 3 minutes to empty water from the drum then stop automatically.
If the pump is blocked or the drain hose blocked or kinked then water will be left in the drum.
Blockages are usually caused by buttons, bra wires or metal objects from pockets eg coins.
The pump can be popped open using simple tools ie screwdriver and any obstruction removed easily. The drain hose can be detached and a metal object eg knife dropped through to test for a blockage.
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
112 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
