I have a series 80 kenmore washing machine it want spin are agiate what could be the problem and how do i put the belt back on
  • 5,911 Answers
Your washer does not have a belt that I know of. If this is a recent model Kenmore washer, it is equipped with a direct drive transmission and does not have a belt. More than likely,the problem is a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a ***** under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful.
Posted on Mar 12, 2008
  • Jeff Rockwell
    Jeff Rockwell Mar 12, 2008
    The asterisks in paragraph 2 is supposed to read "s c r e w". There's a reported problem with the websites text checker program.
SOURCE:
Why does my Kenmore 80 series not spin?
Drive belt probably snapped...if you want to fix it yourself to save money...google the model make of machine along with the part you require and add Amazon...which should link you to Amazon to enable you to bug replacement part...same goes for finding replacement items on EBay.....if you take thenrear panel of the machine off..then you will see if the belt has broken or simply slipped off.
Feb 05, 2018 | Kenmore Washing Machines
Kenmore washer 80 series will not agiate
What is the model number of your unit?
Nov 25, 2012 | Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Washer drum not spinning
yes you will most likely need a belt.
Mar 11, 2009 | Kenmore Washing Machines
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
