Question about Canon DR-2050C Path-Through Scanner
Paper problem! all paper went through directly altogether
  • itswendylou Jul 02, 2008
    The scanner will sometimes take letter size docs all the way through with out scanning them. If I have a mix of letter size and legal size it will stop once it feeds through a letter size sheet.
I was having the same problem, called Canon, they said to open up the front, and use a little rubbing alcohol on the rollers to get all the dust and residue off. There's three rollers on the part that faces you and two rollers on the inside of the door that pulls down. Occasionally, these do need to be replaced completely because they develop flat spots and won't pull it through.
Cleaning the rollers helped and now I do that once a month.
Posted on Aug 04, 2008
Fan the paper and try less pages.
Posted on Jun 05, 2008
After running my kia 3.5 with out water car stopped i put water in started her up went a mile stopped altogether and then had to get towed home what damage have i done to her
Sounds like the engine got very hot and possibly distorted the cylinder head. That means the head will need to be removed and shaved down until it is perfectly flat where it seals to the block. Check the compression on all the cylinders. that will tell you alot. If the compression is lower than 90 psi on any cylinder or if the pressure varies greatly from cylinder to cylinder you will need head work.
Oct 02, 2016 | Kia Sorento Cars & Trucks
I have a Epson Work Force 610 series printer that had a printer jam, how can I reset it?
There may be a scrap of paper still jamming the printer. It needs another look
Mar 24, 2013 | Epson Office Equipment & Supplies
Loud clunking, then stopping altogether
is the Paper feeding thru if not it could be the paper loader in the paper tray which you can fix by finding a object that will sit in there you could also tape it down this sound like it is the paper loader try this and if not Post back
May 26, 2010 | Brother HL 5140 Laser Printer
Out of paper displays on computer when paper has been reloaded
Usually when you run out of paper the driver changes its status to "paused" just right click the printer and select "resume"
Mar 24, 2010 | Office Equipment & Supplies
Printer will not print
Unplug the printer and let it set for a few minutes and plug it back it. This should reset any errors you printer has stored in its memory.
Jan 29, 2009 | HP DeskJet 932c InkJet Printer
Stuck paper in printer
the only solution for this is to dig it out
remove the paper feed cartridge, open the printer up and remove all corona wires, and anything that will slide out
look to see the feed rollers and try lifting on the rollers with your fingers to take any tension off of the top roller always try to remove the paper from the feed area slowly work the paper out if you still see small piece of paper try working them out with a stiff piece of index stock
avoid damaging the rubber rollers with a sharp object and by all means do not force the feed rollers they were designed to move in one direction..towards the copy area a pair of tweezers and hemostats work very well
the fact that the paper went in sideways lends me to believe you have a fed roller problem or an obstruction
once you clear the jam cean the feed rollers with soft cloth and alcohol
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
The paper is jamed with it protruded out in front about a inch
I would try first unplugging the printer, then taking the paper tray out, the toner cartridge out, open the back cover and inside the back cover near the power cord is a blue lever. Try pushing this down as you see if you can remove the jammed paper.
Aug 08, 2008 | Brother HL-2040 Laser Printer
Canon DR-2050C Path-Through Scanner Logo
140 people viewed this question
old marine
old marine
