Question about Imation D20 Disc Publisher - Duplicator/Printer Burner
Bravo SE Auto Printer
I have a Primera Bravo SE Autoprinter that is one of those printers that prints on DVDs. It all works well, but if I have the cartridges refilled instead of buying new cartridges (the reason being that the refills last around 3-4 times longer!) - but the problem I have is that when I put the refill cartridge in the printer still thinks that it is empty, and tells me I need to change the cartridge, which means every time it prints one disc I have to press 'stop' and 'resume print'... which can get kind of annoying... is there any setting to over ride this??
Bravo pro will not print using mac book pro
Sorry to have to break this news to you but if you don't use a printer at least once every few weeks the ink cartridge exit holes dry up and you can't get any ink out of em. There is no fix for this either other than to replace the cartridges. Joe
Mar 22, 2010 | Primera Technology Primera BravoPro...
When I print on the DVDs, the colors are all messed up. It's mostly printing red and yellow in place of Blue, Black and Green. I am using a MAC G5 and the ink cartridges are full. Any suggestions?
First guess is that the cartridges are faulty or missing a color...I refill a lot of these ( are they the 53330 & 53331 or the newer version? ) You can take out the cartridges and press them onto a damp paper towel? You should see a distinct rbg pattern on the towel....otherwise your preferences in accordance with this driver may be corrupted...remove and reinstall the driver first, and then if that doesn't work, remove the preferences folder according to the user and then reboot and try again..after that...let me know..
Jul 23, 2009 | Primera Technology Bravo II AutoPrinter...
Hi i am having trouble printing on the Primera Bravo Pro AutoPrinter. I have checked the ink as well as the alignment but for some reason it won't print. it picks up the disk then the printer hovers over...
If it can print in windows printer settings (puge og alignmemt) i think the printer works.. but is it from shurething or primoDVD .. the problem need to clik the printbox..
Jun 03, 2009 | Primera Technology Primera BravoPro...
Won't print
I think you need to check it with warranty if it comes with it. Because if it has sometime left with warranty try using that. I do believe that if its problem with parts than its different issue. Check if there is an error showed in the PC when you give orint command does it show any dialogue box with error and what is it? Try uninstalling and using its software remedies which comes with the CD.
Mar 12, 2009 | Primera Technology Bravo II AutoPrinter...
Hiya how do i check the inks on my bravo 2 primera
Go into your printer driver; ie. control panel -> printers and right click the CD/DVD printer. Press "Printing Preferences" near the bottom of the Properties window. Click on "Clean/Change cartrdiges & check Ink" and select properties.
Mar 05, 2009 | Primera Technology Bravo II AutoPrinter...
Need a 64 bit driver for my primera bravo 2 printer
Hi there and welcome to FixYa,
you will find your driver here:
regards and  Happy New Year /Teis
Dec 29, 2008 | Primera Technology Bravo II AutoPrinter...
Primera Bravo CD/DVD printer -- prints blank
Let the printer repair itself. Got to start menu select the printer then select properties. Go to maintenance menu try all the basic testing. If it still didn't work out, delete the previous driver and install it again, then restart and try printing again.
Dec 14, 2008 | Primera Technology BRAVO AUTOPRINTER (Open...
I can,t print
this usually indicates there is a problem with the cartridge, check the bottom of each cartridge and see if the colour barcodes are intact and ensure you are not trying to start the machine with the lid up as too much light coming in will also cause the problem when reading the coloured barcodes on the bottom of each cartridge
Apr 16, 2008 | Primera Technology BRAVO AUTOPRINTER (Open...
Imation D20 Disc Publisher - Duplicator/Printer Burner Logo
95 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
