The 1100 sometimes gets into a state where the alarm and countdown timer make no sound or vibration (though the screen flashes when they activate). "Restore factory settings" doesn't help. The only way I can restore normal function is to take out the battery to completely reset the phone. My firmware revision is "V 7.36 21-11-05 RH-18". (find out by typing *#0000#)
Try to check the warning alerts, if is in the no sounds mode,
change it in to yes...
Posted on Mar 12, 2008
May 12, 2017 | Watches
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
Dec 27, 2010 | General Tools Hardware & Accessories
Nov 12, 2010 | Watches
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
Oct 25, 2010 | Remote Transceiver 5BCR
Oct 05, 2010 | Watches
Oct 27, 2008 | Timex Watches
Sep 01, 2008 | Nokia 1100
Nov 05, 2005 | GE Slim Spacemaker 7-5295 CD Shelf System
Jul 10, 2014 | Nokia 1100
Jul 04, 2014 | Nokia 1100
313 people viewed this question
Unfortunately that's not it. I tried turning off warning tones, and the alarm still sounds.
