Question about Pioneer HDJ-1000 Professional Headphones
No sound on right side
I bough my headphones one year ago an their been working good, but about i start having one problem with the right side just doesn't sound i already check the cable, plugs and there is not any cut or something like that ...
  • 2 more comments
  • Anonymous Nov 23, 2008
    yea,wats with that, my right side of my less than one year old head phone is working too well either...PLZ help
  • Justincaze Nov 29, 2008
    I have the same problem aswell, They broke in the plastic, I got a new pair, but the right headphone started to crackle and is now dead. How come? Can we fix it?
  • Anonymous Dec 09, 2008
    My headphones have been working really well, with good quality sound and stuff like that. This was untill a couple of days ago when i was using them, i went to go somewhere for a while and I left them plugged into my computer, when I got back, they were suddenly only woking in one ear!
    It is soooo annoying!!
  • Anonymous Jan 03, 2009
    The same problem - Sound on right side interrupts. I noticed, that it is happening when I'm moving the cord just in the place where it comes-in to the (left) headphone.
    I was trying to find out how to unscrew/dismount left headphone and check out cable connection, but I don's see any screws on headphone.
    I heard problem can be repaired.
    Other solution is just use warranty ;) ...
I had such a problem, but I fixed it.
Plase see video on YouTube:
or read this brief text explanation:
Under/behind the ear sponge are four screws - 3 black screws, that holds ear cup closed, and one silver cup, that mounts small piece of plate, that holds the cord.
Gently unscrew, open ear cup, and then first I suggest to check if circuit on that small circuit board is not broken! You can also check wires, etc.
DawidWarsaw
Posted on Jan 13, 2009
SOURCE:
Only the left side of my Blackweb Headphones work. What's the problem?
While they may be wireless, there is a cable that runs from one side to the controller on the other side. Check this cable to make sure there are no outward signs of damage.
Mar 19, 2017 | The Audio Players & Recorders
I have the RS120. It worked ok for about 2 years and then the right side stopped working. The left side works just fine. I opened up the sides and it seems that there is no broken solders or anything...
well it seems your right earpiece is started to get broken...clearly saying that the coil has static and would result to an open coil.....try to replace with a new one...good day...
Feb 12, 2011 | Sennheiser RS 120 Consumer Headphones
I can here a music in headphone on one side only that is right side but not on left side i have tried many headphone to it but it can be here only one side so plz tell me setting how can i able to here on...
This is a simple problem and fix. The headphone jack goes bad and only one side or no sound at all will play. They are very cheap and easy to replace. Ebay has them for around 3 dollars complete with lock switch and you can find a how to video on youtube. Tools come with some of these and are very helpful in opening case and opening ribbon locks. You will need a mini philips screwdriver as the only other tool. Hope this helps and good luck. This is how i repaired mine two years ago and still works. I would suggest ordering two jacks because of wait time and they are cheap.
Jun 14, 2010 | Apple iPod MA446LL/A MP3 Player
Problem with Motorola S9 Wireless Headset.
Check:
  • Your sound card's Mixer Panel to ensure you have left/right adjusted properly
  • Your sound card may have a speaker-test function, my RealTek tests with "Left" "Right" speech
  • Check your connectors (head phone & speakers) to ensure they are compatible with your sound card
  • Make sure the plug is FULLY inserted in the speaker card socket, it doesn't take much NOT to be fully inserted
dont forget to rate me.......
good luck......
Apr 15, 2010 | Motorola Mobility S9 Headphones
No sound on right speaker
I would check the cable and plug. A break near the plug would kill the sound. If you are still not certain then, it would be worth cutting of the old plug and fitting a new one. Cutt the cable 10cm from the plug, just to make certain you keep away from the area most likely to fail.
Mar 04, 2010 | AKG K 240 Studio Professional Headphones
Samson Stereo Headphones RH100 - no more sound
first u have to check the wire from pc to headphone whether any wire is damaged ,next u check whether the volume in the headphone is mute, and then check the pc volume whether it is in mute .rate as u like
Oct 16, 2008 | Samson RH100 Headphones
Aspire 3680-2574 Headphone jack
did you try another set of head phones? the jack for the headphone where it was soldered most likely broke off you can take apart and try and resolder it.
Jan 04, 2008 | Gateway M305CRV Notebook
right click my computer--> properties-->hardware-->device manager-->sound devices-->find realtek hd audio-->right click-->disable-->OK
wait at least 3 min
repeat and enable
Oct 09, 2007 | Computers & Internet
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
Pioneer HDJ-1000 Professional Headphones Logo
1,684 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
