Question about Sony Cyber-shot DSC-W50 Digital Camera
Error E91:01 on DSC H7
I am having DSC H7. I am getting error E91:01. Because of this the symbol of flash is continously blinking and the flash is not working. I had shown it to the repair center, they are saying that the main special circuit board is out of order and expense for the same will be around Rs. 15000. Is there any solution for this? What will happen If I am using it in the same way without flash?
  • 4 more comments
  • Anonymous May 11, 2008
    i am also facing the same problem pls suggest the solution and send me mail vijutv@gmail.com.
    regards
    viju
  • Eduardo10 May 30, 2008
    I am having DSC H7. I am getting error E:91:01. Because of this the symbol of flash is continously blinking and the flash is not working. Is there any solution for this?
  • LOLMP3 Jul 11, 2008
    I had same problem after getting camera slightly wet on vacation. All was fine but continual flashing E91:01 message and no flash working. Tried the suggested reset via setup and initialize and it worked GREAT!!! Thanks for the tip!
  • felipe d s Jul 14, 2008
    I have exactly the same problem. For no reason, the flash is not working and I got E:91:01 blinking on the display. The camera wasn´t hit or wet, and was working perfectly the day before the error appeared.
    I hope somebody could help me to fix it. Thank you.
  • madboxer1 Oct 15, 2008
    hey guys i have the same problem with my camera.
    i tried to reset from main setting, i changed the date and everything but the first minute it sems to be resolved but when i tried to use flash it bling yhe same error code and its make me crazy.
    please help me this is my e-mail adress.
    madboxer1@hotmail.com
    thanks for everything
  • JayakrishnaM Oct 22, 2008
    Kiran, I am having the same problem what you had. I am having the same DSC H-7. Did u get any way to recover it ? After going through the steps mentioned in this page for 3 to 4 times, I haven't got recovered completely from that prob. I will try some more times and will see what will happen.
I had this same problem. Go to Home / settings / main settings / initialize. This resets the camera and you will need to reset the date-time.
Posted on Jun 06, 2008
  • 74 Answers
Hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Posted on Oct 17, 2008
Having the same problem on a dsc-p9. any idea?
Posted on Oct 14, 2008
E:91:01
The error message indicates that there is malfunction occurred. Please perform a power reset by removing the battery and reinserting it after 2 minutes. If the issue persists, service may be required.
Mar 04, 2012 | Sony Cyber-shot DSC-H7 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Sony dsc-h7 E:61:00 error
Below is detail of Error
f8b5q9ipcdnk0yaaaaasuvork5cyii=
Procedure how to replace Lense
dwbfbffpyq5kaaaaaelftksuqmcc
i2cie0ly39aaaaabjru5erkjggg==
Now you can get every thing related to fault.
Kind regards.
Aug 01, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
How do I turn my flash on--I have a sony cybershot DSC HF camera! Thanks!
Do you mean a DSC H5? If so, at the top of the control button there should be a symbol that looks like a lightning bolt with a arrow on the bottom. Push that to go through the various flash settings.
You can get the manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-H5&region_id=1
The 'Read This First' file is a quick guide to using your camera and is also available on that page. And, if you didn't mean H5, then you can change the model.
Aug 01, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Flash is not coming and error code is E:91:01
Hi!
E:91 is flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in Sony service center.
Tom
Jul 17, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I use w210 Sony Cybershot! Error E:91:01.
I use w210 Sony Cybershot! I was taking pictures out in the sun, when I saw smoke coming out the camera and the camera become very hot. I also saw that I was using the camera bymistakely in the twilight mode out in the sun. And since then I tried intitializing it but the Error E:91:01 and flash symbol wont stop blinking. And flash Seems to have stopped working. Please help me to solve this problem
Jul 14, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
My sony model is dsc-h7 full hd 1080 15x optical zoom 8.1 megapiksel
I CHECKED SOME DIFFERENT SITES FOR SOLUTIONS AND FOUND ONE THAT PROBABLY MEANS MORE TO YOU THAT ME, NOT BEING FAMILIAR WITH YOUR CAMERA. IT STATED THAT TO RESET THE ERROR ONE NEEDED TO GO TO THE CLOCK SET MENU, TURN OFF THE CAMERA AND THEN REMOVE THE MEMORY CARD. THIS WAS SUPPOSE TO RESET THE ERROR CODE. I HOPE THIS HELPS YOU. WISH I HAD ALITTLE MORE TO GIVE YOU, BUT IF THE PROBLEM IS STILL THERE REPLY AND I'LL SEE WHAT ELSE I CAN FIND. GOOD LUCK!
ARCLIGHT1217
Oct 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
Jul 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
File error
Format the card, if that fails to fix the problem try a different card.
Jun 02, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
523 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
