Question about Palm Treo 650 Handheld
Cleaning glue from the palm
I dropped my palm in a bucket of glue- I have taken it apart and need to know what should I let it soak in to get it cleaned. If thats what i should do!!
  • stone101 Mar 12, 2008
    I heard there was an alcohol you could drop the electronics in for a day and it dislodged everything
    Problem Solver:
  • 36 Answers
Kinda depends upon what kind of glue. You /may/ be able to rinse off the electronics with distilled water ... however if the LCD is gunked up you really don't want to soak it in anything.
Posted on Mar 12, 2008
How to repair egr on 1996 ford f150
if you remove the egr and soak it in a bucket of engine cleaning additives, use cotton buds and an old tooth brush. to clean off muck agitate it in the bucket but leave it to soak for a few hours. and before fitting make sure its dry.
Jun 13, 2017 | Ford Cars & Trucks
HOW DO I BREAK APART THE SOUND STICKS TO REAPPLY THE BACK CASINGS OF THE 1" DRIVERS. IS THERE A WAY?
If the backs of your 1" drivers are off, they're broken, and you need to replace the drivers.
Nov 02, 2014 | Harman Kardon SoundSticks II Computer...
Its not working for me plz help. Bush 40inch smart tv remote is not working
Did you ever get the remote control wet? If so it can be taken apart and cleaned of any sugary contamination with water, a drop of soap and a toothbrush... dry and then put back together. If it is imperfect crazy glue foil to the bad buttons
Oct 21, 2013 | Televison & Video
I want to ask how can I stitch my shoes together again and clean it
Most shoes are not stiched where yours are coming apart, they are just glued. I would try some super glue or heavy duty epoxy glue. things like normal white glue wood glue or things like that wont work because the area will be constantly flexing. As for a good cleaner just use a good dish soap that says it works on grease/oil, and scrub them in the sink and let them soak for awhile before you rinse them off.
Mar 04, 2013 | Clothing Accessories
I ve been reading about the ribbon an glue problem with the zif or tcon ribbons.what i would like know where is the glue spots are? so is it at the ends or what?
they are talking about inside the panel where you cannot get to where the ribbon cables directly connect to the panel..........
Apr 13, 2012 | Sanyo Televison & Video
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
I get DE back into my pump strainer and I only can filter for 2 to 3 hours before pressure is up to 20 to 25 lbs and I have to use bump handle to start filter again with results
The de coming back into the pump isnt anything serious, there may be a small air leak causing the water in the filter to drain into the pump.
As far as having to bump every couple of hours... is the pool really dirty?
Is your pressure gauge broken? Turn off the pump, does the gauge drop to zero? Alot of times they dont drop to zero, so when you hit 25psi it may really only be 15. Happens alot actually.
If pool is clean and clear and the gauge is fine... have you ever taken apart the filter and cleaned the de fingers? If not, i would take it apart, rinse all of the fingers and then let them soak over night in a filter cleaner solution. This cleans them much better then a plain garden hose spray. After they soak, spray them down again, add new de and you should be good to go....
Aug 15, 2010 | Hayward EC-40 DE Pool Filter with pump
My Minolta Di151 keeps jamming up in the paper feed I have practically taken it apart Any suggestions?
Clean sep pad, clear take up roller, check one clutch spring inside large white gear (clean and lub) also check the solinod bad spring, tacky glue for sponge that is on lever up part of solinod. check electrical connection to soln. Replace entire sep unit.
Jul 02, 2009 | Minolta Office Equipment & Supplies
Psp inop
If you have insureance take it back to where you got it from and replace it without the urine!
May 22, 2008 | Sony PlayStation Portable (PSP) Console
Bissell Powerforce Bagless Vacuum
Either your hose is plugged, or the inlet by the brush roll is plugged. Another problem that can cause this is the the filters are clogged or may just need to be replaced. Most of these has a filter in the dust catch bucket, and also above the bucket. Make sure all filters are clean.
Jan 05, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Palm Treo 650 Handheld Logo
16 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
