Doesn't turn on any more
Started to shake the image and then goes off, now doesn't turn on any more.
  • 1 more comment
  • Anonymous Jun 18, 2008
    my tv was workin and then it just went of and it will not come on again
  • Anonymous Dec 24, 2008
    sharp tv 25r-s100 25 inces tv suddenly turned off doesnt turn on anymore
  • Anonymous Mar 01, 2009
    I have the same problem with my sharp tv turned off will not come back on help in Phoenix Az
Check horizontal osc
Posted on Mar 12, 2008
SOURCE:
Image shaking, foggy and looks kinda like static
It will be best to contact any service technician in this case. Gopakumar Gopalan Google
Apr 19, 2014 | Samsung LN40D550 LCD TV
1994 Toyota Camry doesn't start without shaking
sounds like it having trouble starting. when was the last tune up ,and are there any codes on.
Nov 03, 2012 | Cars & Trucks
Why doesn't my car stay started?
try giving it a little fuel to keep it going. if it still goes but will shakes and splutters and coughs before smoothing out it sounds like fuel is draining back from your engine to the tank. if you have an electric fuel primer pump that turns on when you turn the ignition to on you should be able to hear an electric whine unless your car either does not feature one or its not audiable/ possibly not working. leave your car at "on" for 10 seconds then try starting it as well. see if it improves
Sep 17, 2012 | 2005 Chrysler Pacifica
Difficult starting. If I shake the wire gently it will start. Sometimes goes for weeks with no trouble. Then all of a sudden i turn the key and nothing. When I get out and gently adjust the wire it...
The problem is that wire is, for some reason, not making proper contact. Start by taking it off it's contact point. Check it for corrosion, looseness and possibly broken strands of wire where it goes into the terminal end. Clean all surfaces to bare shiny metal and change the terminal end and put it back together. While you have it off, trace back over it looking for bare spots in the insulation. If you find any tape them up with electrical tape and reposition the wire so it doesn't recur. It's also possible that there is a break inside the insulation in which case you will have to replace the wire itself. Hope this helps.
Aug 07, 2011 | Cadillac DeVille Cars & Trucks
Walk mate does not work
you need the GPS headphones (sold seperately) to be attached. Then walk..... it will count your footsteps...
Jun 06, 2009 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
SONY DSC H9 image shakes
CCD Failure!
known problem contact sony for free repairs dont worry just call them they will do it even if u are out of warranty
see this for sample advisoy and problem detail
http://esupport.sony.com/US/perl/news-item.pl?news_id=161&mdl=DSCT1
Apr 20, 2009 | Sony Cyber-shot DSC-H9 Digital Camera
Monitor issue
Look to Caps on the inverter if its an LCD or flat pan. monitor.. Weve seen this be4..
Jan 13, 2008 | Norcent Technologies LM-762 17" Monitor
COPIER
its self adding toner, besure your cartridge is not empty, take it out and shake it side to side. youll feel if its got toner, Remember kids, when you shake up toner, it gathers air and will leak or pour just like water. you may have to turn off & on so it completes its stir cycle a couple times. By they way, i,m not an apprentice or rookie. long time service co owner.
Dec 07, 2007 | Kyocera CS-2050 Black and White Copier
Camera shakes when turned on and when taking a picture there is a black area in upper left corner
This soundfs like a Zoom lens element problem May be expensive to get fixed Check out customer support
Jul 31, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Ekse
