Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Where can I order a replacement screen from ?
I had the red convergance go out and i replaced the chips i saw everyone was having problems with. tv has been working great for a while.now I need to replace the front screen assembly. it has scratches and dark discoloration in it . I think the kids hit it with a ball or something.I remember it didn't look hard to replace when i was in there. I just can't find the part ! Does anyone have a place to get these ?
  • Vista Electronics May 11, 2010
    Please confirm your TV Model # off the back of set......T.
  • 58 Answers
This may help, the part # is 56sc-001a-m2. Unfortunantly you cannot order just the front screen. It only comes as a set of screens, (lenticular and Fresnal). vance baldwin shows it for $400.00. Hope this helps.
Posted on Apr 02, 2008
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My philips 46PP8621 is cloudy and any white in the picture is so bright, i need shades. I cant fix it. It is unwatchable. Please help!!!!
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 15, 2009 | Philips Televison & Video
My magnonox is cloudy too!
You guys are awesome! I picked up one of your kits and fixed my TV in less than 1 hour. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Jun 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture too red and too bright
Problem #2)
  • Screen looks 3D
Jun 12, 2009 | Philips 64P8341 64" Rear Projection...
Different color shadows appear.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
3-d looking picture on top and bottom of screen
  • Screen looks 3D
Apr 25, 2009 | Philips 51PW9363 51" Rear Projection...
Red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
Apr 08, 2009 | Hitachi 46F510 46" Projection HDTV
Bowing at top and bottom, can't adjust convergence replaced IC
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Mar 22, 2009 | Toshiba 57H81 57" Rear Projection...
Red "aura" in the middle of my 55" Phillips Magnavox
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Turns blue and has shadows
  • Screen looks 3D
Sep 10, 2008 | Sony KP-51WS520 51" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
