Error Code 'No Input Device Connected"
Samsung LCD TV Error Code
  • richied824 Nov 29, 2008
    I am trying to connect my Wii to my new samsung lcd tv and it always says "no input device connected" even though all the cords are connected.
3 Suggested Answers
SOURCE: Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Posted on Sep 20, 2008
Hello!
This Samsung LA40C350 TV requires all pins are connected from D15 D15 VGA cable
Some cables what they sell in market dont have all wires connected. Only RGB, Grounds and Horizontal and Vertical sync but missing other connections
Samsung uses those other pins detect if PC is connected or not.
Next time you buy VGA cable, take multimeter with you and check that all pinns are connected through, before buying cable.
Best Reg: Eero
Posted on Jan 31, 2009
Connected the new Dstv Explora to my Samsung LCD TV, but nothing is working. No sound, no image
Go into the settings and change the input until you see the picture and have sound
Mar 25, 2015 | Samsung LN32A330 32 in. LCD TV
What is the audio/video input?
Hi
Audio Video input or [AV] input is meant for to connect the TV to any external device which has AV output. For example, you can connect the TV with a DVD/VCR/Blu-Ray/Amplifier etc. The audio video output of the connectig device has to connect to the audio video input of the TV with an audio video cable. This cable can be bought from most of the electronic sparepart shops. After connectin it such, you have to go to the input selection window of the TV and must select the input of the tV to Audio Video. No tuning or any other adjustment should be done then. Just play the connected device and see the its output by Tv. OK.
Jul 10, 2011 | Toshiba 37C3030D 37 in. LCD Television
When I switch on the unit, i can hear the sound but there is no picture
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the device for example DVD player is connected to the TV. At the back of Samsung's LN40A650A HDTV are three HDMI inputs, plugs for component input, an antenna input for the DTV receiver and a VGA input. Please check on what port the device is plug.
To correct the issue, use the TV's remote control and change the video input selection.
  • Press the Menu button on the remote control and navigate to TV Input
  • Only ones that are actually connected are highlighted and available.
  • If there are multiple device connected please make sure you select the device you want to connect.
You may also check if all cables are properly connected.
Thank you.
Mar 12, 2011 | Samsung LN40A650A LCD TV
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
TV/vcr
VCRs are usually connected in Audio-Video inputs of TVs.
Please check what input is being used in TV for VCR cable hook up at rear of TV. Select that AV input in TV by remote and enjoy.
Oct 03, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Mar 08, 2008 | Televison & Video
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
