Hi i have a 93
Thanks arwilson for the help! so far i've located the ic 2004 but i can't seem to find the jumper between the pins 2 & 6. and could you please help me understand what you mean by "jump pins 6 & 7" also please tell me where to look. thanks for your time Roy
    Scholar:
  • 87 Answers
The jumper looks like a staple from the top side . It is soldered to the bottom of the board. The copper trace can be followed from pin 2 through the staple ( jumper ) to pin 6 of IC 2004. Remove the staple ( unsolder from the board ) then solder the staple from pin 6 to pin 7 of IC 2004. The IC has a notch at one end. Pin 1 is the first pin to the right of the notch looking down on it from the top. The pins are in consecutive order 1,2,3 etc. Hope this makes sense.
Posted on Mar 13, 2008
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
Mitsubishi WS-65807 convergence - keeps blowing F9A04 pico fuse?
You\'ve already gone a hundred times as far as anyone else within a hundred miles of you, Dave. 8)
It might be the case that something else was borderline & couldn\'t tolerate the convergence being corrected. If that sucker\'s VERY old, I don\'t think I\'d chase it very much farther, myself... you may never get any rest.
Or... it could possibly also be the case that you overheated a lead on one of the ICs. They can\'t tolerate very MUCH heat - barely enough to get it hot and get it done. Especially if you soldered the leads sequentially instead of alternating like Pin 1, Pin 14, Pin 2, Pin 13, etc.
If the ICs were\'t very expensive, you might try it one more time - ICs and picofuse. Take every precaution not to overheat the IC leads. If it doesn\'t work THIS time, donate it to a good cause unless you simply like challenges.
Aug 07, 2014 | Mitsubishi Televison & Video
Vestel 11ak36a15 no vertical deflection
Check the track for any brake. Check the resistance between 10pin and 6pin. If IC is short, you can determine it by this check. tda8174-pinout.jpg
Oct 31, 2012 | Televison & Video
D641/BLR DOOR CHIME CHANGE CHANNELS
Open the back of the door chime and the button press.
On the back of both of them there is a set of jumpers.
From left to right there are 6 available frequencies. You need to grab to jumpers to join 2 of the pins together (top and bottom pin). If you don't have a jumper just use a set of pliers and cross the 2 pins together (top and bottom pins) on a channel you wish to use. Repeat the process for the button press if you've just done the door chime. The 2 pins that you've joined together needs to be the same as you've just done for the door chime.
Note the red jumper on the button press, selects the type of door chime you want to hear. this is the 4 right hand side pins on the button press. The far right is a long chime and second in from the far right is a shorter chime.
Hope this helps, figured it out by trial and error. :)
Sep 19, 2012 | Bell Cocoon Child Carrier
My Toyota Sienna shows VSC light on the broad. What Should I do?
If you've had your vehicle computer codes read and determined no issue with the VSC circuit, then you just need to cancel the warning light.
I've made up the following instructions, on how to clear VSC & TRAC Warning lights:
Zero Point Calibration of Yaw Rate and Deceleration Sensors Using Paper Clips (or jumper wires).
First, locate the 16-pin ODB II connector under the steering wheel (beneath the dash). The pins are numbered sequentially backwards from right to left (from the wide side of the connector looking at it from underneath).
Take two normal-sized paper clips (or suitable jumper wires). If using paper clips, straighten one edge of one of the paper clips. For the other, bend it open to a 90-degree angle (like an elbow).
Insert one paper clip/wire into pin # 14 (Ts), and the other paper clip/wire into pin # 4 (CG) of the OBD II connector - DO NOT allow the paper clips/wires to make contact at this point.
Refer to diagram below:
1. Ensure the shift lever is in "P" range.
2. Turn the ignition switch to "ON" (not start).
3. Momentarily touch the two paper clips/wires together (short) and separate again (open) - Repeat this process 5 times (within 8 seconds of turning ignition on).
Verify that the VSC indicator light is illuminated, indicating the Recorded Zero point is erased.
4. Turn the ignition switch "OFF".
5. Remove both paper clips/jumper wires from the OBD II connector.
6. Turn the ignition switch "ON" (not start) - wait until VSC warning light turns off (approx. 20 seconds), then wait 2 seconds.
7. Turn the ignition switch "OFF".
9. Re-insert paper clips/jumper wires to terminals #4 & #14 of the OBD II connector (as per above diagram).
10. Turn the ignition switch "ON" (not start) - VSC warning light should remain illuminated for 4 seconds, then start flashing at 0.13 second intervals.
12. After VSC warning light flashes for 2 seconds, turn the ignition switch "OFF".
13. Remove paper clips/jumper wires from the OBD II connector.
Drive your vehicle to confirm VSC & TRAC warning lights have been reset and no longer illuminate.
"If this has helped you resolve your issue, please be kind enough to leave a testimonial"
Jun 10, 2011 | 2001 Toyota Sienna
Reset bios to factory settings in dell optiplex gx520
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
Can click the link below to see how its done or follow the steps below :--
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=87&~cat=12
Choose the desktop model and continue.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Else can follow Optiplex User Guides.
Hope it helps !!
Thanks.
Sep 14, 2009 | Computers & Internet
Motherboard not powering up
hi this is parveen
solutiom for d845gvsr not poweringup only led flashing--
short pin 92 and 93 of smsc LPC47M172 with fine tip soldering iron .
pin 92 is nrsmrst signal that is 3.3v at time of working m/b when this signal is low than motherboard not powering up so we short pin 93 that is standby (3.3v) and motherboard powering up again and working properly this problem doesn,t come again in future. this solution is 98% working 2% chances to change the chip.
Aug 07, 2008 | Intel Motherboard
Maxtor hardrive
If one of the jumpers shorts two pins and the other jumper is a single pin short, remove the two pin jumper. The single pin jumper should be located on the pin at the far upper right corner. should be set as a slave at that point.
May 26, 2008 | Maxtor Hard Drive
Hi i have a 93 Mitsubishi model# ck35402. I was told that the pip had went out. was hoping someone could walk me through on how to remove and reroute
From the bottom of the main board locate IC 2004 between the PIP module and the tuner. Remove the jumper between pins 2 & 6, then jump pins 6 & 7. Next , pull the pip module from its socket and toss it. The symptom for a bad PIP module could be black screen, no picture, blue streaks, wavy or jittering picture.The audio will not be affected. Make sure the symptom fits the cure before you bypass the PIP. Good luck!
Mar 12, 2008 | Televison & Video
No power-up only the little green light by the cpu lights up
I tried Parveens solution for this problem on 2 absolutely dead D845GVSR mother boards and it fixed the problem for me on both. On mine you had to permanantly short pins 92 & 93 of the LPC47M172 IC near the ddr ram slots.
There must be a reason for why the motherboard went dead in the first place because from the factory, pins 92 & 93 of this IC are not meant to be shorted. Albeit the motherboards work perfectly the shorting of pins on this IC get over the problem but the original fault is still really there but has been bypassed! Still having said that, what a result!
Feb 02, 2008 | Intel Motherboard
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
