Question about Garmin GPSMAP 60CS GPS Receiver
Gpsmap 60c can not acquire satellites even when left outside for 15 minutes in a place where it usually has no problem. Problem happened overnight.
  • RSP1856 Aug 19, 2008
    My Garmin GPSMap 60CSx worked fine, then could not see any satellites the next day. I tried a hard boot (holding "page" and "enter" while powering up), new software (version 3.70).
    Now I notice that the clock and calender are wrong.
    Please help!
I tried a "Hard Reset" by holding down "Enter" "Page" and zoom"OUT" during powerup, starting with the power off. That did the trick!
Posted on Aug 19, 2008
  • 3 Answers
Are there any there any satellites listed on the satellite overview page?
What is the GPS SW Version listed by the unit?
0.00?
Posted on Jun 10, 2008
My navigation icon is dark and do not work .what can be the problem and where can I download the maps
  • If your device is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the device is powered on and outdoors with a clear view of the sky, this should not take more than 3-5 minutes.
  • If your device does not have full view of the sky while placed in the car, it may not acquire satellites properly. For best satellite acquisition, mount the device on the windshield or dashboard.
  • If your device has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites.
  • If your device is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your device or you have performed a master reset, your device may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your device has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the device receiving signal, your device may need an external antenna in order to acquire satellites.
    • If you suspect this to be an issue, try taking the device outside of the vehicle with a clear view of the sky for 3-5 minutes so that the device can acquire satellites. If your device loses satellites once moved back into your vehicle, you will most likely need an external antenna
May 19, 2015 | GPS
GPSmap 76CSx is not acquiring satellite
Update the unit using Garmins WebUpdater program, this may fix your issue as there was a chipset update that is crucial to acquiring satellites. here is a link to the software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 07, 2011 | Garmin GPSMAP 76CSx GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
When i turn on my gpsmap 60 cx it never acquires the satellites,it stays on this screen.
I had this on my Tom-Tom once. I think I reset it using the poke-a-pen-in reset switch, turned it off, charged it up with USB cable, updated it from the site, then went outside with it and it then finally acquired.
Jun 05, 2010 | Garmin GPSMAP 60Cx GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
No satellites signal
Update/Reload your unit's GPS and sytem software via Garmin page or use Web Updater. Your unit will be functioning again. This problem also occurs if you leave your unit on a dash board in a car and it is exposed to hight temperature.
Mar 08, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
The GPS cannot get satellite signal. It only displayed "acquiring satellite" considering that we are in open fields with clear sky.
Shut off the Receiver...
Press and hold Page + Menu + Power...
Then select "Yes" to erase all user data...
Leave it on with a clear view of the sky without moving for about 30 minutes to acquire the satellites.
Nov 28, 2008 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPSmap 76 not acquiring satellites
You need to do an auto locate. This also corrects your time issues (wrong date and/or time will be corrected. To do an auto locate do the following.
  1. Start with the unit turned off.
  2. If you have a GPSMAP 76, GPSMAP 76C, or GPSMAP 76S, hold down the Page button. If you have a GPSMAP 76CSx or GPSMAP 76Cx, hold down the Zoom Out button.
  3. While holding down the first button (Page or Zoom Out), press and hold the Power button.
  4. Continue to hold the two buttons until the Satellite page displays. You can then then let go of the buttons.
  5. Finally, let the unit sit outside with a clear view of the sky. Allow about 20-40 minutes for the unit to acquire satellites.
May 01, 2008 | Garmin GPSMAP 76 GPS Receiver
Not acquire sattelites
place the GPS outside with a clear 360 degree view of sky or as much of the horizon as possible and leave it for a few hours it needs to download the almanac from all satellites before doing this
from the Acquiring Satellite page press menu and make sure that the topline of the menu reads "Use With GPS off" if it reads "Use With GPS on" (this means it will not find any SAT's ie for indoor use) press enter to turn the GPS Receiver on
Jan 01, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60CS GPS Receiver Logo
169 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
