Question about Philips Magnavox 27MS343S 27" TV
Sony TV Problem model # KV-27V42
I have a sony 27" tv no pic or sound when turning set on I hear power relay click 4 or 5 times set will not come on checked 4 amp fuse ok.
It appears to be in start up circuit these switching power supplies can be very hard to troubleshoot.
I thought someone may have had same problem.
Any help?
  • Dwight Biddle Mar 15, 2008
    Thanks I checked first thing,HOT HAS DAMPER diode across E&C thought it was ok.
    Took HOT out of circuit,now have one on order, hope fly back is ok.
    Thank again
    Thomas
  • 55 Answers
Your tv has a  short  circuit, the power supply see that and put away the polarizatio n , you have to check  if transistor of power on flyback transformer is  good
or bad - delfo
Posted on Mar 14, 2008
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
Feb 18, 2009 | Sony KV-27V42 27" TV
Control Board Problem???
Switches can be cause of this problem but I been experienced SysCon IC defective many times.
Jul 27, 2008 | Sony KV-27V42 27" TV
Sony trinitron kv-27v42
Horizontal Out Transistor is shorted and have to replace it.
Jun 25, 2008 | Sony KV-27V42 27" TV
KV-27V42 27 - 4 blinks
horizontal output transistor (HOT) check IC1751 for short between pin 4 and 6
Apr 02, 2008 | Sony KV-27V42 27" TV
Sony KV-21GMR1
Your enquiry (not even a question) is very obscure. There are many things in a TV set that can cause "No Picture".
Does the TV have sound at least, or is it just dead???
Common failures in priority order in this model are in the scan amplifiers and power supply, audio output, the tuner module, and the CRT.
Your set will require service.
Jerry G.
Mar 20, 2008 | Sony KV-27V42 27" TV
TURN TV ON FIVE VOLT RELAY CLIKS 4 OR 5 TIMES STILL NO PIC OR SOUND
If ur processor has 5v vcc then set could be in protection mode.
please give me the no. of processor ic so can i help you
regards
rawan
Mar 03, 2008 | Sony KV-27V42 27" TV
Unavailable Part
More properly called the "A" or main board.Can be repaired by
a qualified tech in a shop setting.Possible horiz or power circuit
problem.
Oct 15, 2007 | Sony KV-27V42 27" TV
My TV won't come on!!!
you have powersupply problem .you wil have to have it checked by tech sorry
Mar 22, 2007 | Sony KV-27V42 27" TV
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
