Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Maytag mfd2561 water dispencer and ice maker issues
Posted by Texasguy on Sep 29, 2007Report abuse Hi all. I have MaytagMFD2561HES french door and water dispencer doesn't work. I replaced the filter(was year old) but it didn't work. I hear the motor running and when I replaced the filter water was running from the bottom of the freezer. But it was stopped after few mins. My ice dispencer doens't work, door alarm doesn't work and water filter and replace indicator doesn't work. Both freezer and refregerator works fine. Display shows correct temp, vacation mode, and other funtions work. I didn't use the fridge for year (used it for 8 months only) and any help would be appreciated. The electronic controls on my Maytag refrigerator model MFI2568AEW keep flashing and the ice dispenser flap keeps running. I noticed someone else on here had the same problem. I pulled the front off and unhooked the controls to stop the banging of the dispenser flap. If I order part # 12002608 is it going to be something I need a professional to install or can I just plug it in myself? Thanks.
  • 1 more comment
  • Anonymous May 11, 2008
    Everything was working just fine. Then the popping and flashing started. Determined the popping was the sound from the ice chute cover opening, then snapping shut. I taped this cover open, so the loud popping would stop - now just have a clicking sound. And for the first few hours, the display would occasionally reset to normal. Now I have continual clicking and some flashing. [Initially, the entire display was flashing. Now it's just the temperature blocks and a few other lights.] I took out two screws, but can't figure out how to get anything else off, and I'm not going to force anything. It's the weekend. The store where I bought the refrigerator was not help - just gave me a toll-free in-house number that had closed. Now I'm looking for a Maytag toll-free help hotline number.
  • b0ivy May 22, 2008
    I have the same problem. The temp on the firdge will not get below 57 and the flap kept opening and closing. I disconnected the 4 wires on the upper right behind the panel to make it stop..
  • lhy2000 Jun 05, 2008
    my water suddenly stopped dispensing
    President:
  • Maytag Master
  • 2,651 Answers
Ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Posted on Mar 12, 2008
2 Suggested Answers
the dr
  • 447 Answers
SOURCE: maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Posted on Sep 29, 2007
MaytagMFD2561HES french door slams open
theoabear,  Seems I ran into this before,  check out the following post the cat here posted.....Catriver
http://www.fixya.com/support/t129304-maytag_fridge_french_door_hinge
Oct 19, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
cbn,c,bm
Jun 14, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Water dispenser not working in my Maytag Model #MFD2561 HES
Hi. Do an Internet search for Maytag recalls. Your fridg. may be on their list. If this solution has assisted you, please rate it. ricardok45.
Dec 27, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
623 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
