Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Problem wd-62927 after it warms up the colors go out, turn it off and after cooling fan shuts off turn back on and it works for 10 more minutes.
    Sergeant:
    Champion:
  • 301 Answers
Most likely having a optical engine failure. the most expensive part of the tv no less. suggest having a tech go and evaluate.
Posted on Mar 29, 2008
  • emfarfan Aug 17, 2011
    did you ever get a solution to your problem. I have the same thing only mine runs for 2-2.5hrs like clockwork then it happens. Tonight I placed a fan behind it and watched for 4-5hrs with no problem. I will have to check for fan issues, what did you do to fix yours.
Similar situation as previously described with the Denon AVR-1508, but mine will shut off after about 10-12 minutes the first time around and then ~2 minutes after it is turned off and then back on. Unit...
Most new receivers have a fan on the back, if you have one check to make sure it is working, most won't activate until the unit gets warm, other issues are bad solder connections on the audio outputs causing intermittent shutdown, as a final inspection check speaker connections to the receiver and speakers.
Sep 18, 2011 | Denon AVR-1508 Receiver
Mitsubishi WD 62927 not turning, no picture...
It sounds as if you have the lamp unit out. Had the same problem myself. Sorry.....
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
2004 s40 volvo-ac works for 10 minutes then gets warm.
evaporator leaking or condensor fan inop
Jul 31, 2009 | 2004 Volvo S40
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Ghosting and color issues still occurring
Glad to help. How do I get to the Youtube link?
May 27, 2008 | Mitsubishi WD-62927 62" HDTV
check your air intake filters, it's a removeable filter in the air inlets.
May 04, 2008 | Televison & Video
2yr old DLP TV flashes for few mins then has red tinge
Push the menu button when the problem shows up again. Please tell me if the flashes show up in the displays as well on the menus. I can take it from there.
Apr 15, 2008 | Mitsubishi WD-62927 62" HDTV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
