I`ve a RCA L32wd14 tv everything works fine but it does not have sound.the solution is not in the menu or speakers.the problem is in the main av board .do you know if i can do something to get it going?
Re: i`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
You may have failing power supply module or failing main board, you need to do some voltage cheking at the outut terminals of the power supply to see if the voltages come and go.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L32WD14+
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
howdmwl,
I don't if you are still online but I would like to let you know how to get you tv repaired.
You find a TV service center and tel them to fix it.
If they are not able to reair it, you take your work order and call 1-877-297-8391 and they will exchange your tv
