Question about Akai LCT2715 27 in. LCD Television
Akai LCT2716 Flat Panel TV
Light blinking red (bottom right); TV will not power on; some popping sounds in speakers I have a LCT2715 that will not power on , it has a red flashing light and static popping noises coming from speaker.
  • 2 more comments
  • Anonymous Mar 20, 2008
    Almost exactly the same situation as described above.... Turning power on results in no image displayed/ black screen.... audio is only a popping sounds that begins low and gradually builds to a medium volume.
    60Hz cycle popping???
  • Anonymous Aug 21, 2008
    Flashing Red Light & Popping sound in speakers
  • Maxs Sep 02, 2013
    When i turn my tv on it shows the picture but has popping atatic sound and gradually gets louder and louder
  • Anonymous Mar 30, 2014
    no video
    Problem Solver:
  • 4 Answers
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
By saying 'POWER BOX' it that 'POWER SUPPLY'? If so, $280 is way too high of a price, $100 max
Posted on May 21, 2008
You need a new power box. Cost about $280. Good luck
Posted on Mar 24, 2008
  • 30 Answers
I can repair these for you for $150.... email twizted at dragonmods dot net
Posted on Jun 25, 2008
Red light blinking and no response akai LCT2715
The led is blinking due to fault in power supply board.
On the power supply board there are some capacitors and ICs .if any of those gets short or faulty the power supply board will create problems and the red light will start blinking. The components on the board needs to be checked with the help of multimeter and continuity tester.And the faulty components needs to be replaced with the help of soldering iron. the procedure to check the power supply board is as follows:---- 1) You are going to need a Phillips ( X ) Screwdriver for this procedure. The first thing you will want to do is find a suitable location to disassemble the TV. Try to find somewhere with plenty of space to work and preferably somewhere you will not have any hazards such as static (like carpet)
Lay the TV Flat on its face (picture side down) and remove the 4 screws from the back of the TV holding the base on.
Next you will want to process to remove the screws around the back cover. There are 12 screws you will need to remove (refer to picture for locations).
Carefully remove the back panel of the TV. It may snag on the coaxial connector so be careful.
2) Once you have the back off of the TV you can see the Main board and power supply covers.You will now need to remove the left (right side from the back) speaker cover to allow access to two of the screws holding the Power Supply Cover in place. This is easy and pretty straight forward and has 8 screws around the perimeter.
Once you have the speaker cover off you should be able to access the screws on the side and you will also want to remove the other screws from around the sides of the cover. Some TV's I have worked on only had 6 where others had 7 or 8. Just make sure to remove all of the screws before trying to remove the cover.
Once you have the cover removed you will see the Power supply. Remove the wiring harnesses from the power supply board. You will have 4 cables at the top of the power supply and one main power input at the bottom. The main power input may have some glue securing it in place. Simply cut this with a knife or pull it loose.
Once you have the cables off of the power supply you can remove it from the TV via the screws on the 4 corners. Be careful not to damage anything as you remove these screws. You now have the Power Supply removed from the TV.
you can now get the power supply repaired from any local tv repair technician.or get new replacement power supply from the service center.or from online stores like : www.partstore.com or from www.shopjimmy.com
Thanks. you can rate this solution and show your appreciation.
May 13, 2010 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
27 akai lct2715 POWER SUPPLY
Have you had your power supply repaired? If not i can possibly help you with this issue.
Nov 07, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2715 Blinking Power Light
Hire a tech directly to replace all the bad capacitors on the power supply PC board.....................T.
Aug 03, 2008 | Akai LCT2716 27 in. LCD Television
AKAI LCT2715
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 31, 2008 | Akai LCT2715 27 in. LCD Television
Power light blinks red - tv will not come on
to let you all know that Im having the same problem with my tv.. amber then red red red red... and popping sounds from speakers... Its because they use cheap parts there are 19 capacitors in the power supply (DONT RECOMMEND FOR NON EXPERIENCED PEOPLE) the 2 main filter capacitors are 100uf450v the ones in mine are just fine then there are 3x 1000uf16v, 2x 470uf16v, 3x 470uf25v, 2x 1000uf25v, 6x 1000uf35v, and 1x 470uf35v... Im in the process of replacing those capacitors. about half of them are leaking and 1 is blown... very dangerous for anyone messing around back there.. just thought i would let everyone know that its a 20 dollar repair if you know what you are doing i got my caps at marvac.com
any other questions email pfctmitsubishi@yahoo.com
Dec 04, 2007 | Akai LCT2715 27 in. LCD Television
Power supply for Akai LCT2716 27 in. Lcd tv
http://www.discount-merchant.com/SearchResults.asp?Search=hy342-5991-09c&Search.x=20&Search.y=13
I think this is the one you need. I have a lct2715 which I opened up for the same reason and thats the power supply number on mine. Not sure if the 2716 is the same though.
Sep 23, 2007 | Akai LCT2716 27 in. LCD Television
Akai lct2716
you have fault oscillation you hve defective parts inside!
Sep 14, 2007 | Akai LCT2716 27 in. LCD Television
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Apr 09, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
278 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
