JUMBO Universal remote bought at family dollar
Need codes for a jumbo universal remote bought at family dollar.
heraulfur
  • 23 Answers
SOURCE: need jumbo universal remote codes
try this website "www.remotes.com"
Posted on Apr 25, 2009
pabloloco
  • 2335 Answers
SOURCE: Through Amazon a Brookstone's "Jumbo
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
Posted on Oct 26, 2009
Testimonial: "You explain clearly - we'll follow your recommendations. Whether they will solve our problem won't be known until we try them. Hoplefully they will."
rmoseng
  • 77 Answers
SOURCE: I need the Innovage jumbo universal remote codes for my RCA TV
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Posted on Dec 17, 2009
superminer
  • 26 Answers
SOURCE: Jumbo Universal Remote Control
DIRECTV all models 00001, 00002
also use 200-217 from the jumbo hand book good luck
please rate
Posted on Jan 13, 2008
scott201201
  • 170 Answers
SOURCE: i need innovage jumbo universal
what kind of tv are you using this on?
Posted on Apr 10, 2008
Lost manuel how do I program it
Danny, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovage Jumbo Universal Remote
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
How To Program The Innovage Jumbo Universal Remote Control
JUMBO Universal Remote Codes Codes For Universal Remotes
May 03, 2016 | Innovage Jumbo Universal Remote Control
LG codes for a jumbo remote
Check these codes. 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Oct 22, 2012 | Jumbo Universal Remote TV DVD VHS...
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
COde to let a Universal Jumbo Remote work with a sky+ HD Box
don't have a answer! i need a code for my jumbo control for my tv Samsung DYNA Flat
Dec 29, 2008 | Universal Remote Control Remote Control
Bigmatters universal jumbo remote ero4307j
manual de codigos del control bigmatters jumbo universal mod ero4307j
Jul 05, 2008 | Televison & Video
PROGRAMMING
I have a Universal Jumbo Remote from the Dollar Store and have no codes to program it to the TCA television. ? Can you help?
Feb 09, 2008 | Innovage Touch-panel Phone 1502084
Televison & Video Logo
631 people viewed this question
Top Televison & Video Experts
Electro Med Services...
