I have an old square slider type honeywell thermostat. romm temperature based on thermostat is 20 degrees C. i set the slider to off or left most which i assume is zero or 10 degrees. is this all right. i want lowest gas bill possible
Check for cold air inside the wall behind the thermostat, a cold wall, and area that is getting hot or cold air blowing on the thermostat. Last, the heater may not be compatible with some digital thermostats.
Honeywell Customer Care toll-free at 1-800-468-1502.
How do I set one temperature for the whole day? To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
If you are successful in setting it lower , you will end up with frozen pipes and large plumbing bills. Since the internal walls of a building can be as much as 20 degrees lower, that the room.
And the location of the thermostat, may be even warmer, that that of the areas where the plumbing is.
Now what is your reason for wanting the thermostat operate at a lower temperature?
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
