Question about Sony Playstation 3 (PS3) Console
Play station 3 internet
I have the wireless internet card from verizon that runs off a cell phone signal. i can get internet on my computer even when im driving, but when i tried to hook up the ps3 through an ethernet cord it would not detect the internet??? do i have to have a traditional internet to my house or can i use this card?
Use your laptop to share the internet with the ps3.
Posted on Jun 22, 2008
  • sirbarker32 Jun 22, 2008
    Use your laptop to share the internet with the ps3. Connect to the internet on your laptop. I don't know what your operating system is but if it is vista or xp it is really easy. Just go to Start then Help and support. Type in share internet. Follow the instructions. Turn of your computer. Hook a lan chord from your laptop to your ps3.
    Turn on your laptop and connect to the internet. Turn on your ps3 and change the settings to wired instead of wireless. Let it config everything manually. It should connect.
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
My ps3 cant find the ip adress and has perfect internet signal
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
My nokia 6111 has a virus and doesn't want to switch on
sir, just follow the steps below, 1. Switch off your phone...
2. Remove SIM card & memory chip...
3. Now press & hold keys - 3,*,call green) ...
4. Then without leaving these three buttons press power button...
5. Formatting task will be started...
6. Remember its a very rare trick....
sir please rate my answers too
Dec 29, 2010 | Nokia 6111 Cellular Phone
I have a 2002 Compaq Evo N600c that has been sitting in a closet for a year. I have just connected it via a Netgear card to my Verizon wireless network. My wireless network connection says I have...
You may have to contact Verizon for this so they can connect you. They will ask for such things as your computers' MAC address which can be found on a sticker on the bottom of the computer chassis. The MAC address is a unique identifier for your computer. Much like a fingerprint no two are the same. The signal strength that your computer is showing you is rather misleading; it is meant for notifying you of the connection between it and the wireless signal being sent from another device such as a satellite or wireless router, NOT that you are actually receiving data from the internet. There are some other parameters and internet protocols that your computer will need to be set up for, all of which your internet service provider (Verizon) will get established for you over the phone. It shouldn't take more than 10 minutes.
Nov 08, 2010 | Compaq Evo N600c Notebook
I have an older computer that does not have a wireless card, but my internet is through a verizon um175 air card. i have gotten 10 different answers, and none work. 3 different answers from verizon alone...
Yes you can. Make sure that you disable DHCP in the lan settings section in the router. Use the computer without wireless card as the server, the router will be install in this computer. i have an air card with Sprint and I'm using Encore router and my Wii, and 3 more computer can connect without any problem.
Aug 31, 2009 | Toshiba Satellite A135-S2276 Notebook
Kazaa music for Verizon compatability
As far as downloading songs with the internet, yes, VCast is your only choice for Verizon.
However, you are free to sideload your .mp3 formatted files from your computer to your phone via a microSD card, or data cable, no matter where they came from.
If you're going to use a memory card, you'll need to insert it into the phone and format it (its under Menu > Settings > Memory usually). Then make sure that you only load the files into the music folder for them to work.
Jul 28, 2009 | Motorola Cell Phones
PCMCIA Verizon BroadBand Internet PC Card
You COULD do it, but man.
you are gonna be charged for each MB used, and honestly, it would be a terribly impractical approach.
Just to humor you, you'd do it as such.
Set up your laptop to run all the time. Have the Verizon card plugged in, and always active, and set to never drop connection. You'll now need a crossover cable, and you'll run the rj45 crossover from the ethernet on your laptop to the WAN port on your router. You'll then need to bridge the connections. Some versions of Windows support internet connection sharing; effectively doing the same thing. Now, you should have active internet.
Now, you're going to be charged per MB, you're gonna have a SLOW SLOW SLOW SLOW connection, and you should expect $1000 phone bills monthly.
Mar 31, 2009 | Lenovo Verizon Wireless EV-DO Embedded...
I cant play online without the modem being by my ps3?
Yes, using a longer ethernet cord will work, but the PS3 has a bult-in WiFi card that can connect to any wireless router (you can buy a wireless router from a computer store like BestBuy).
If you are going to buy a wireless router, see if a wireless G-mimo or wireless N with signal boost is within your budget. Try looking through the network settings to see if you can connect through the wireless router.
Or just get a longer ethernet cord and run it directly to the PS3 from the router. Ethernet cords are the most reliable connection, granted you are on a good internet connection, they won't get interference from things like mobile phones, cordless phones, microwaves, TV's etc.
I have both the PS3 and Xbox 360 and the only thing I like better about the PS3 is the free online game play and Blue-Ray. Other than that, they're even. Good luck and have fun online! If you find me (wraith0127) say hi! Don't forget to rate. Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Connecting my PS3 to the internet using a 3G Verizon Broadband
Unfortunately the PS3 will not be recieving internet through this device, the USB connectors are set up to only work with PC or MAC specifically for that reason that gamers cannot use their Xbox or Playstation, and that is because Verizon offers a Wireless router cell phone data device which costs almost a thousand dollars, definately not worth it.
Jan 28, 2009 | Sony Playstation 3 (PS3) Console
Verizon Wireless Card not working with Dell
contact dell and let them know there is a hardware issue with this card they may have a driver work around
Apr 07, 2008 | Dell Inspiron 700M Notebook
Sony Playstation 3 (PS3) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
