Question about Sony Playstation 3 (PS3) Console
Will not turn on
Checked the plug and switch at the back ok!
  • 4 more comments
  • edge540 Mar 18, 2008
    yes i checked the fuse and it was blown do to a short on the cuircut board i substitute it with a different power supply and she's back up and running thanks guys
  • stickmegood Apr 05, 2008
    my ps3 will not power on someone help!!!
  • Anonymous Apr 06, 2008
    Where is the fuse
  • Anonymous Apr 07, 2008
    I connected my PS3 to a front projector but when I turned it on... it didn't. No power at all....
  • joshgarr92 Jul 17, 2008
    my ps3 will not power on at all i think the fuse blew how do i fix it?
  • Alex Cotterill-Drew
    Alex Cotterill-Drew May 11, 2010
    Have You checked the fuse?
  • 128 Answers
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me.
Posted on Mar 15, 2008
Why does dslite have no power?
Make sure the ribbon cables or the screens are plugged in. one for each screen and one for the touch screen (i think the touch screen is the one thats causing your problem) its small and comes out easily. please wright back if it works
Sep 05, 2014 | Nintendo DS Lite
Compaq presario cq71 power indicator comes on for about 5 seconds then turns off without battery
cq71 check tips:
please clean memory stick pins and slots first if not ok, check next
1) plug in adapter to check jack led lights on or not, if no lights on no switch on.
2) if the jack lights on, then to switch on laptop, will be showing the more lights on, you are hearing cpu fan running. if nothing appear or every thing running with dark screen, or hard to switch it off go next
3) pull out the wireless card then switch on again, see what happened, if ok change a new card, if not ok, it is motherboard hardware issue
Dec 29, 2012 | Compaq Presario CQ60-220US PC Laptop
Brand new Whynter ARC 12 SD, just plugged in and red warning light about power button is blinking. Booklet says the light will blink when water reservoir needs to be emptied. But, it's brand new, no...
Check the positioning of the water bucket It may be slightly out of place and is not triggering the switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit for 12 - 15 minutes. Then plug it back in and turn the Master Switch ON/OFF Switch to ON. Set the controls and it may have reset itself.
If none of the above soled the problem contact the manufacture's Customer Support or Tech Service Dept.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 05, 2011 | Whynter Portable Air Conditioner
It seems as if the thermostat for the oven is not working.
GAS UNIT:ELECTONIC IGNITION
1ST MAKE SURE .(IF ELECTRONIC IGNITION, CHECK TO MAKE SURE THE PLUG FOR YOUR STOVE IS PLUGGED IN. IF IT IS PLUGGED IN AND YOU CAN'T GET IGNITION, THEN CHECK FOR TRIPPED BREAKER OR BAD PLUG IN OUTLET, OR GFCI RESET SWITCH IS NOT TRIPPED. IF ALL IS OK THEN MAKE SURE YOU ARE GETTING GAS TO THE UNIT. CHECK SELECTOR KNOB FOR PROPER OPERATION OR CRACKS TO MAKE SURE IT IS OPERATING PROPERLY. IF ALL IS OK THEN REPLACE SELECTOR SWITCH,THERMOSTAT IS CONNECTED TO THIS SWITCH.)
GAS UNIT:NON ELECTRONIC IGNITION
1ST MAKE SURE ALL PILOTS ARE LIT. MAKE SURE YOU HAVE GAS COMING TO THE UNIT. IF ALL IS OK, THEN DO THIS:
REPLACE OVEN SAFETY VALVE OR THERMOCOUPLE OR ADJUST THE FLAME HEIGHT AT THE OVEN PILOT. ALSO CHECK OVEN SELECTOR SWITCH FOR CRACKS OR PROPER OPERATON. CHECK THE SELECTOR SWITCH 1ST. IF ALL ARE OK THEN TURN OFF GAS TO THE UNIT FROM BEHIND THE STOVE AND REPLACE THE SELECTOR SWITCH, THE THERMOSTAT WIRE IS CONNECTED TO THIS SWITCH.TURN GAS BACK ON AFTER REPLACING THE NEW SWITCH AND CHECK FOR GAS LEAKS.
ELECTRIC UNIT:
CHECK THERMOSTAT KNOB FOR PROPER OPERATION. MAKE SURE IT IS NOT CRACKED. IF NOT CRACKED , LIFT OVEN TOP AND CHECK FOR LOOSE WIRING. IF ALL IS GOOD, CHECK FOR CONTINUITY ON UPPER AND LOWER ELEMENTS. CHECK BY REMOVING ELEMENTS, GET MULTIMETER, WITH ELEMENTS REMOVED, TURN METER TO VOLT/AMPS AND TOUCH RED TEST WIRE TO ONE END OF THE ELEMENT AND THE BLACK TEST WIRE TO THE OTHER END. IF IT READS OR MOVES AT ALL THE ELEMENT IS GOOD. TEST THE OTHER ELEMENT THE SAME WAY. IF ALL IS GOOD, RECONNECT ELEMENTS INSIDE THE OVEN. REPLACE THE ELEMENT. YOU CAN ALSO CHECK FOR VOLTAGE TO THE SELECTOR SWITCH WITH THE METER TO MAKE SURE IT IS GOOD BEFORE REPLACING THERMOSTAT.
Apr 13, 2010 | Kitchen Ranges
Husqvarna rider 155 won't start
I took a wire and jumpered all of the switches until I found the one that would let the mower start. The switch was still good, but vibration or whatever had moved the plug just enough to lose contact. Plugged it on more firmlly - problelm solved. Thanks.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
try checking the ignition switch for any damage and replace if necessary
Nov 25, 2008 | Garden
Legend 11 Kirby, sometimes will not turn on
Could have a problem with the motor, may need carbon brushes, or other motor related parts. If the light turns on and off with the switch, then the switch is probably ok. There is a speed switch inside the motor casing that could be bad.
Feb 21, 2008 | Vacuums
My DeLonghi D14527DZ will not "power up"
FIRST OF ALL YOU COULD CHECK THE FUSE IN THE PLUG IF THIS IS OK THEN CHECK THE THERMOSTAT SWITCH TURN IT BACK AND FORTH AND MAKE SURE YOU CAN HEAR A CLICK IF NOT REPLACE THE SWITCH
Feb 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Acer aspire e500 won't turn on
Check that all the power supply units are switched on( Wall Plug, UPS, CPU), If all is ok and the problem exists, replace the CMOS battery.( if the sys works replace your CMOS Battery, configure the cmos settings also)
Jan 03, 2008 | E-Machines T1360 PC Desktop
Sony Playstation 3 (PS3) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
john o grady
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
