I have a Kenwood amplifier KA-78, ALL OF THE SUDDEN THE VOLUME WENT OFF AND THEN CAME BACK ON AND THEN THERE IS NO POWER. What gives, does it have a fuse?
  • 4234 Answers
SOURCE: Purchased vintage KENWOOD AMPLIFIER KA-6000.
I believe that that model uses coupling caps between the fron end and the final stage. Check those as well.
Dan
Posted on May 05, 2008
mebeog
  • 8 Answers
SOURCE: my kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Posted on Dec 04, 2008
SOURCE: how can i find a
Any universal remote capable of controlling a stereo should be able to control the volume, power, and muting. Beyond that my experience is that hitting random buttons will sometimes get other functions, eg. the "2-/12" button on my universal remote changes it to CD mode :/ You just need to find the codes for Kenwood in the instructions or online, and try all of them.
Sorry I'm a few years late, but I hope this will help anyone else with this problem.
Posted on Sep 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: The model number is Kenwood
The manual with 'specs' is here. Take them with a grain of salt because it's impossible to produce more audio watts than are consumed electrically (250 total).
http://www.retrevo.com/s/Kenwood-KA-894-Amps-review-manual/id/479ag211/t/1-2/
Posted on Dec 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an old kenwood
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Posted on Dec 30, 2010
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
How do i get a free service manual download of a kenwood ka-127 model stereo integrated amplifier in any digital format?
I doubt you will be able to find a digital copy, and Kenwood dropped their home audio line 2+ decades ago. I probably have a hard copy of the manual, as I was a Kenwood Factory Service Center for over 25 years, however, it is not free. If you would like more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 11, 2014 | Audio Players & Recorders
Kenwood ka 7x
salut a tous quelq'un a un amplificateur kenwood ka x7 je veut connaite les tronsistors qui porte cette amplificateur le mien etait enlevr je connais pas les refferonces je demonde de l'aide et mercie beaucoup a +
Oct 05, 2013 | Televison & Video
How to connect a kenwood ka- 9100 to a pioneer vsx-d608
You don't say, what role the Kenwood is supposed to play but I'll assume you want to slave the Kenwood (and its speakers) to the Pioneer.
The VSX-D608 doesn't have multi-channel pre-outs so you wouldn't have local control of the volume at the Pioneer.
http://www.auctiva.com/hostedimages/showimage.aspx?gid=108365&ppid=1122&image=404270323&images=404269872,404269931,404269984,404270049,404270137,404270323&formats=0,0,0,0,0,0&format=0
The KA could be a subwoofer amp as the Pioneer has a pre-out for that.
Outs to Ins. "Power In" on the KA would be for an external volume-controlled source. Otherwise, use one of its non-Phono inputs.
http://tubehacker.com/sale_item.php?item_id=31
May 29, 2011 | Kenwood Audio Players & Recorders
KENWOOD KA-99 INTEGRATED AMPLIFIER MANUAL
Hi...
Does it look like this?
http://www.hifiengine.com/manuals/kenwood/ka-9x.shtml
Mar 27, 2010 | Kenwood Audio Players & Recorders
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Kenwood KA-127 P-off response
This unit is likely to be in "protect" mode. This means that a problem has been detected it the final stage of the amplifier section and the speakers are disabled to prevent damage to either the speakers of the amp. This can be casued by a poor solder connection or defective components inside the amp. Without taking internal measurements, I can not say for sure. Expect a parts cost in the $25-$40 range for this repair. Add in the local labor rate for the total repair cost.
Dan
Nov 30, 2008 | Audio Players & Recorders
Amplifier will only put out "faint" music, etc, even when the volume is turned all the way up
This may sound silly, but please check to be sure that the tape monitor switch in not engaged. Update this if that is not the problem.
Dan
Sep 29, 2008 | Audio Players & Recorders
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
207 people viewed this question
 Grubhead
Grubhead
