Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Canon powershot sd 300
My flash is not working
  • 22 Answers
Most likely your flash bulb burned out or was damaged. If you feel comfortable opening your camera you can buy a flash module on the internet or ebay for around $20-$25 and install it yourself. If you do so, be VERY careful NOT TO TOUCH the capacitor as those things can store a massive amount of voltage even when the battery is removed and the camera has been off for some time.
If you don't feel comfortable opening your camera and trying to replace it yourself, my suggestion would be to get a new camera. Repairs by Canon usually run more than $100 and the SD300 is a bit old to be laying out that kind of dough, in my opinion.
Posted on Apr 15, 2008
My flash stopped working i have CANON 340 hs powershot n when i took without flash its giving me results
Try to reset the camera settings, then press the flash button (lightning symbol) and make sure it's set to ON mode.
if it still does not work you might need to replace it
Dec 05, 2014 | Canon PowerShot ELPH 340 HS Black Digital...
Maximum sd card for canon powershot s2is
SD cards max out at 2GB. The S2 will not work with higher-capacity SDHC cards.
Mar 27, 2013 | Canon PowerShot S2 IS Digital Camera
CANNON POWERSHOT ELPH FLASH WONT WORK
Try this place for help with it: www.camerasandparts.com I'm sure they have a flash service for your model since they deal with the Powershots, they're the place if you need help with a Canon. They're not expensive at all and the work is superb on the Powershots. Plus they service up the rest of the camera at the same time which is nice. If you need help with it, they'd be the place. I don't have their email but it should be somewhere on their site. Good luck with it.
Jul 05, 2012 | Canon PowerShot ELPH 300 HS 12.1 MP...
My canon powershot sd 1200 wont turn on i have recharged the battery. what else can i try?
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Jun 01, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Have canon powershot what is best to use a 2gb
Hi and welcome to Fixyah,
I believe that canon can only use SD card you can used 2gb sd card.
Mar 18, 2010 | Canon PowerShot S2 IS Digital Camera
Cannon Powershot SD 870
you can change it to no flash by when your taking a picture press the right arrow
Jul 01, 2008 | Canon PowerShot SD870 IS Digital Camera
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Where does the SD card go
Its on the side , take a look at this screen shot, it will help ya good luck!0aa1bd5.jpg
Dec 16, 2007 | Canon PowerShot A75 Digital Camera
Cannon powershot sd 300
flash may have been dislodged and out of true. or may be the lens is out of alignment or a shutter blade is not functioning. Dropping them sure does them no good at all. Into the repair shop with it
Jun 03, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
182 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
