Question about RCA Scenium D40W20 40" Rear Projection HDTV
RCA D40W20YX1 unknown chassis numbers
I started with blue screen with green, blue, and red across the screen and the volume was so low almost couldn't hear it. then I moved the two wire vertical deflection cable and it flashed from somewhere and now I have no volume and when you try to turn it on it comes on goes off comes on goes about three times and thats it, but I have no power light on and you can switch power off and hear it go off. I don't have diagrams for it, not sure where the flyback transformer is, but I do have a spare set of circuit boards. Any Ideas please HELP
    Genius:
  • 1,694 Answers
The flyback transformer is probably bad...it has a large red
power lead coming out that goes to the HV divider....need
drawing # s off the body of transformer to confirm correct
part #.....................T.
Posted on Mar 12, 2008
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to replace red crt on 52" RCA
When a red crt goes out and wont light its usually another reason such as a transistor or even faulty CRT pc board that causes it since the set powers up the other two tubes. Go to this link and leave them an email and list the model number and tell them the symptoms they will help you out with it, they are real good with the RCa sets. If the red tube was shot it would cause the set to go into shutdown or throw red retrace lines across the screen. Heres the link,
http://servicemanuals.vstore.ca/
May 21, 2008 | Televison & Video
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
Convergence problem on RCA HDTV
What is the model and chassis number for your set? Te chassis number is most important to diagnose a RCA set. Please post the chassis number located on the rear panel of the set.
Feb 23, 2008 | Televison & Video
RED GREEN BLUE CONVERGENCE IS OUT.
What is your Chassis # ? And convergence problems can be some of the most hard to realign. You may need to replace amps.
Jan 08, 2008 | RCA P52926 52" Rear Projection Television
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
RCA Scenium D40W20 40" Rear Projection HDTV Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
