Question about Kitchen Ranges
Gas GEXL44: Oven does not work
I have a gas GE XL44. When turning the oven on, the temp light shows as working but the oven does not light on. The broils however works but not the oven. I appreciate if you can guide me on what the problem might be. Thanks in advance.
  • 1 more comment
  • Guimarp Mar 12, 2008
    Thanks. I am searching for the parts and they range from 65 to 80 dollars. I am inlcuding a link found at the Repair Clinic. The seem to match with your desription. Would you be able to confirm if this is what you are refering to?
    Thanks one more time for reading and answering my inquires.
    http://www.repairclinic.com/SmartSearch/...
    Thansk very much.....I will try and let you know. Once again, thanks for your prompt help!!!!
  • jimpolo Mar 14, 2009
    My Xl44 will not ignite a flame. I hear the ignitor working on the stove top but no flame. The oven also stays at 100F. On occasion the stovetop will light only after the ignitor is clicking for a couple of minutes. I also sometimes smell NG but only momentarily.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Oven never lights , but shows its on,? never heats past 100 deg?? soundslike a bad bake ignitor to me take down the model number and order a bake ignitor, installs on the bake burner, under the floor of oven, with just a few screws and 2 wires.
Posted on Mar 12, 2008
  • Ron Coons
    Ron Coons Mar 12, 2008
    that is indeed the part i was referring to. as long as its ordered for your model, good to go!
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 05, 2009 | GE Kitchen Ranges
I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
201 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
