Question about Mmats D500.2 Amplifier Car Audio Amplifier
Mmats d500.2 ive got an mmats d500.2 is it bridgeable&what ohms is it capable of.. whats the wattage ratings on it.. ive got2 15w0 8ohm JL also a 15w6 JL audio & would like to know the best way to hook them up any help would be great thanks BATMAN
    Sergeant:
  • 300 Answers
  • It is capable of driving a 2 ohm load.
  • It is a single channel amp, so bridging is not applicable. There are two speaker connections, true, but they are tied together internally.
  • It's rated at 500W @ 2 ohms
  • The issue you're going to have hooking up the subs you own is that you're not going to be able to optimize the output of the amp. If you hooked all of them up in parallel (both 15w0 as well as the dual voice coils of the 15w6), you'd be putting a 1.7 ohm load on the amp, which it may not like. In my mind, your best bet is to either put both 15w0's in parallel (125W per sub) and not use the 15w6.....OR.......use only the 15w6 with the dual voice coils in parallel (350W to the sub).
Posted on Mar 12, 2008
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
What way should I hook 2 12" jl audio to a jl audio 1000/1
Is this sub an svc or a dvc? From what I looked up they are svc, so each sub's voicecoil is 3 OHMS, connecting them in parallel would lower them to 1.5, and your amp is capable of going down to 1.5 ohms. So I would suggest running them in parallel.
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
(Although from the information I gathered these subs have 3 OHM voicecoils, so in the diagram where is says 4 OHM it should say 3 OHM, and the 2 OHM should say 1.5 OHMS.
This is a good site to help calculate OHMS: http://www.bcae1.com/spkrmlti.htm
Hope this helps.
Nov 11, 2010 | Jl Audio 12W7 Car Subwoofer
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
    Hello m1k377060,
    Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
    The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
    Hope this helps.
    Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
    Jl audio 300/4 low ohms light wont go off
    If the low ohms light is on then you have your speakers wired to low. I need to know some more info like what type of speakers you have running on this amp and how many. Also was it working before and then it started doing this? Check the ohms with a volt meter if you know how, if not just get a volt/ohm meter and set it to the ohms setting and then take the positive(red probe) and touch it to the positive terminal on the speaker and then the negative(black probe) to the negative terminal and see what it reads. Make sure you check how low in ohms your amp is capable of handling. If you don't know just google the model of your amp and you will find a site that has a manual or just go to JL audios web site and you should find out there with no problem. Let me know what you find so I can assist you more if need be cause I also repair amplifires for a living and have many years experienc and I'm the cheapest amp repair business you will find any where. Good luck
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
    Aug 15, 2009 | Jl Audio 300/4 Car Audio Amplifier
    I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
    Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
    Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
    Good luck and don't worry!
    May 26, 2009 | Jl Audio 12W0 Car Speaker
    Need resistors for JL 500/1
    If you have the old ones that you are trying to replace, Radio shack has tons, as well as guides to show you how the bands are deciphered. Hope this helps
    May 25, 2009 | Jl Audio 500/1 Car Audio Amplifier
    Is a 15 w3 d-4 better then a jl audio w3-d2
    All of the JL W3 subwoofers are essentially the same. The "d2" and "d4" suffix refers to the voice coil configuration. "d2" = dual two ohm coils, "d4" = dual four ohm coils. Depending on the number of subwoofers in your system and the amplifier(s) you are using to power them, one or the other of the configurations may be "better".
    Generally, you want to have the load on your amp to have the lowest possible impedance consistent with the amps capability to operate properly with that load. It's normally referred to as "impedance matching". Greater power (watts) is produced, and louder sound, when the amp can deliver power at a lower impedance.
    If your amp is only capable of supplying power at 4 ohms, you want to make sure that the configuration of your sub(s) represents a 4-ohm load. If the load is higher, say 8 ohms, then your amp can only deliver about half the power of which it is capable. It would be OK to run them a 8 ohms, but they would not be as loud. On the other hand, if the load was lower, say 2 ohms, your amplifier would soon overheat and go into protect mode.
    So the trick is to first decide on how many subs you want. Then choose an amp/sub combination that "matches".
    The DVC or dual voice coils just gives you more options in selecting and configuring. Say you want 2 subs and you are going with the 15w3 d-2. Your amp is the JL Audio G-MAX monoblock. The amp puts out 1200Wx1 Chan. at 2 ohms or 600Wx1 Chan. at 4 ohms. You would wire both of your subs voice coils in series making each sub 4 ohms, then wire the 2 subs in parallel to your amp making the final load 2 ohms, the best "match" for your amp.
    Mar 29, 2009 | Jl Audio 15W3-D4 Car Subwoofer
    500/1 settings to run jl13w6 v2 d-4
    Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
    Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
    Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
    Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
    Mmatsd500.2
    First, the specs:
    • PPI 4200am = 50x4 at 4 ohms, 100x4 at 2 ohms
    • Alpine 3553 = 35x4 at 4 ohms, 50x4 at 2 ohms
    • Mmats D500.2 = 350x1 at 4 ohms, 500x1 at 2 ohms
    • 3x Mmats Procast 12 = Dual 4 ohm VC
    • 1x JL 15w6 = Dual 6 ohm VC
    • 2x JL 15w0 = Single 8 ohm VC
    Second, I don't think I would recommend mixing n' matching the subs. One of the subs would always be working harder than the rest. If you want to run multiple subs, make them all the same. Sometimes, you can get away with it if they are all the same voice coil impedance, but in this case you've got dual 4 ohm, dual 6 ohm, and single 8 ohm subs all in the mix.
    If it were me, I'd probably stay with the single 15w6. But it's your money :)
    Mar 12, 2008 | Mmats D500.2 Amplifier Car Audio Amplifier
    Car Audio & Video Logo
    282 people viewed this question
    Top Mmats Car Audio & Video Experts
    Morne Olivier
    Tariq Waheed
    Tariq Waheed
    Level 1 Expert
    Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
