Question about Acer Aspire 5500 5570-2609 Laptop
Not staying connected
My Acer Laptop will not stay connected with wifi. It comes and goes. Says my signal is strong, connects for a few seconds and all of a sudden, Disconnects.
  • Richard Roberts Mar 12, 2008
    Same thing, Acer 5630.
  • maryam
    maryam Oct 25, 2013
    same problem acerE1-571
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Actually, the LAN port has not problems whatsoever. Its the wireless Wlan. Switches on and off from time to time, cutting off the internet.
Posted on Mar 13, 2008
  • Richard Roberts Mar 13, 2008
    Its our wireless that keeps going on and off, not the LAN. You almost got an inappropriate.
  • 22 Answers
I think you have problem in your LAN port try to buy a USB LAN card 100% im sure it will gonna work.
Posted on Mar 12, 2008
SOURCE:
Will not stay connected to home wifi
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps will-not-stay-connected-home-wifi-5x01jctu1hti52f1zciidmg3-3-0.png
Mar 19, 2014 | Samsung GALAXY S4
Won't stay connected to wifi
reinstall your wifi driver downlodelatest driver from internet and use it if work then ok if not then problem is coming from hadware
Feb 04, 2013 | Computers & Internet
Problem staying connected to internet
If you are connected via Ethernet cable, it works fine? Are all the computers wireless? Does the laptop change when moved? If you place it next to another Computer on wireless is the signal the same? Is this a issue that changes every day you boot the machine? Are the other machines static? Have you done all the Acer and windows updates? Has the laptop always been this way? Way to many variables, It's not a simple question to answer. That said, maybe a bad antenna in the laptop.
Dec 18, 2012 | Acer Aspire V3-771G-6851 17.3" Notebook PC
My Fujitsu wont stay connected to my wireless internet
Maybe the wireless card in the laptop is no good or not strong enough to receive a good strong signal. Try sitting close to the wireless router and see if it loses connection. Does it connect at all and let you on the internet before it loses the signal? If it does not connect at all I'd say you might have an issue with the password or the type of wireless security protocol type you selected to connect with. For example there are different types of wifi security protocol types: (Ex. wep, wpa, wpa2) .
Mar 19, 2012 | Fujitsu Siemens LifeBook E8020 Notebook
I have a Qwest PK5000Z modem and it does not send the wireless signal strong enough to initially connect a laptop in the other room. I can walk the laptop next to the modem and back into the other room and...
There are a few things to try:
  • Move the router to a location that is higher off the floor
  • Move the router off of metal cabinets or away from large metal furniture
  • Get rid of 2.4 GHz cordless phones and buy DECT 6.0 compliant cordless phones
  • Buy a 9DB gain antenna for the router
  • Change the channel that you are using to one that you're not using: 1, 6, 11 (choose the one you're not currently using)
  • If your house has lathe and plaster walls, realize that these walls are like concrete -- they reduce WiFi signals by 13dB ( a lot -- drywall only reduces signal by 3DB)
Dec 31, 2010 | Zyxel (91-004-361002) Wireless Router
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
167 people viewed this question
Ekse
Alun Cox
