Thanks for the assistance
But cud u pls pls tell me how to set the jumper as slave ...do u knw the commands and stuff???? could u pls explain it more clearly like for a layman...thanks again lenny297......
  • Anonymous Mar 22, 2009
    jumper description
  • 133 Answers
Its not a very complex thing to do, remove the jumper from its current slot and place it in the next one, if ur harddisk is using the same IDE cable with the CD then u need to disconnect the CD or buy another IDE cable for the CD. U can read more by downloading this file from this site:
www.wdc.com/en/library/eide/2579-001037.pdf -
i hope the info will assist you
Posted on Mar 12, 2008
SOURCE:
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
How to make master and slave
"Now for a refresher course on hard drive connections. When connectingmore than one hard drive to a computer on the same IDE controller, yougenerally have to assign one as the primary (master) and one as thesecondary (slave). You do this by changing the jumpers on the harddrive next to the power connector. Normally, the drive will have adiagram to let you know which jumper should be set for a master driveand which to set for a slave drive. You'll notice in the picture belowthe jumpers are circled on the end of the drive and the top of thedrive shows the diagram to follow."
Go here http://www.pchell.com/hardware/masterslaveorcableselect.shtml for more..
Dec 06, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
My boot screen shows secondary slave hard disk error press F1 to resume. if i press f1 it enters into bios setup and the i press esc discard changes logging into windows but secondary disk is not detected....
Check on harddrive you find jumper on it.
Then read on harddisk you can find there is specifiaction for master, slave and cable select jumper settings.
Put jumper as cable select then check.
Also reconnect sata or ide and power cable to harddisk.
Then check .
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Computers & Internet
New (used) hard drive
Just remvoe the cd rom and then try to install your hard disk. if it is detected than it means there is a problem of setting master and slave in jumper.
So just check again your jumper settings and read the front side description of hard disk for jumper settings.
Aug 13, 2008 | Compaq Deskpro 2000 PC Desktop
Plz help
there are jumpers on the rear of the unit and changing the position of the jumoer forces the computer to either a master or slave as it boots...on the rear panel it says cbl,sl,ms....ms=master, sl=slave, cbl=cable select...i hope this helps... also after done the jumper thing make sure your ide controller is on for the units on that cable...good luck my email address is troublerst at hotmail if you need further assistance....
Jul 15, 2007 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Open Questions:
Computers & Internet Logo
261 people viewed this question
Ekse
Alun Cox
