I have almost completed a diy modification of a Marantz CD67 Mkll OSE cd player. When I connect earphones the machine plays beautifully. However, when connecting the analogue audio output, sound is only played on one (left)channel. Repeated tests have indicated that both opamps are working. Both input and output legs of opamps voltages are according to service manual spec but when testing the final connection between opamp section output and audio output GND, unusually high voltages are emitted, ( 7 - 9V) where voltage readings should be 0.0V. Any CD player experts able to diagnose and direct me to the section of the board requiring attention and or repair.
  • nuryev Mar 12, 2008
    As mentioned in my request for help, modifications are close to completed. These include Power supply,Hdam bypass, changed opamps, resistors filters capacitors etc. List of modifications can be viewed here:
    Power Supply
    1 C611?614 100u/25V +100n PPS
    2 C651?654 470u/35V +100n PPS
    3 C655?658 220u/16V(wire jumper) Elna Silmic - measure offset Done
    4 C659/660 100p remove - Done
    5 R613?616 27R 1mH/14R Siemens
    6 R651?654# 27R 1mH/14R Siemens 608-609 #optional Removed
    7 R655/656 10k remove - Removed
    8 R657/658 100R wire jumper - Done
    9 R659/660 100R 47R 946-3178 Done
    10 Q605/606 NJM2114D To decide
    11 -insert 220n/PPS between pins 4 and 8 116-6883 To decide
    Output Filter
    1 C601?604 120p 120p/1% Mica 867-901 Done
    2 C605/606 1000p 470p/1% PS Styroflex 952-0058 Done
    3 C607/608 100p 100p/1% PS Styroflex 952-0660 Done
    4 CD21?24 120p 120p/1% Mica 867-901 Done
    5 R601?604 27k 26k/0.1% Welwyn 340-546 Done
    6 R607/608 18k 18k2/0.1% Welwyn 340-586
    7 R609/610 22k 22k1/0.1% Welwyn 320-467
    8 R605/60610k 10k/0.1% Welwyn 949-9938 Done
    9 R611/612 10k 10k/0.1%
    10 RD21?28 10k 10k/0.1%
    These are just the mods I have done to the powersupply and analogue section that may have the problem.
  • 4,889 Answers
I dont know what all modifications you have done but here are some tweaks that would be good:
IMO the tweak steps that should be made and order I suggest is good would be following
1) eliminate the output electrolytic caps from analog output (C656, C658, C655, C657)
I have replaced them with wire jumpers. It would be wise to check the DC component at output connector with multimeter. In my experience it's never more than abou +/- 20mV, which is mostly of no concern. Only if you have a true direct coupled amp where there are no caps in signal line it might happen that the DC component will also be amplified and sent to speakers. I think there is no commercial amp built this way, but some DIY projects might be.
2) Change the opamps. National LM6172 seems to be the most popular candidate and is the one I'm using.
Here the most important is to make sure you will place the additional decoupling caps to the supplies of opamp as close to pins as possible. I have 0.1uF polyprop caps from pins 4 and 8 to ground. When choosing the caps go for the ones that have as small dimensions as possible and as short legs as possible. Also place a cap on top of the opamp between +/- pins (pins 4 and 8). The value of this cap is not critical. Here you should pick some sort of SMD cap with as big capacitance as possible. I used some that were soldered off of some scrapped Intel PC motherboards. It is (at least I think so) non polar cap and the DMM measured it 20uF !!! I don't know if its right but it fits well on top of SMD opamps (I didn't get DIP cases from RS for some reason, even though the part nr. was right). A good place to look for ideas about opamps and decoupling is audioasylum forum.
3)Modify the clock. Install a sepparate one or use the description on acoutica.org site. I did my clock mod very sililar to that independently and as it turns out the techical solutions were similar and also our findings about changes in sound...
4)Better decoupling to supply lines. Use your imagination here.... One warning though, I once decided to change almost all the el. caps in the player for better ones (Nichicon xx, I don't remember the series at the moment). So, I replaced them and to some places I just put bigger values than stock. Well as it turned out I managed to overtweak a bit and now it takes about 30 sec before the display lights up :) I have studied it a bit, also with scope but can't fiqure out what causes the delay. Player starts normally and other than that there is no problem... so I have accepted it as just one more little thing that makes my player special.
Posted on Mar 12, 2008
SOURCE:
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
How do I connect CD player to marantz NR1504 with phono leads
Connect the cd audio out to the line in or cd in on the marantz
Nov 25, 2014 | Marantz NR1504 5.1-channel Home Theater...
Marantz CD5003 CD Player pauses
Not may be! It is. Check and replace it.
Aug 10, 2012 | Marantz CD5003 CD Player
Marantz CDR510 Display is blank
If that is the case there is a missing B+ line to the display, you will need a circuit diagram to find the fault.
Mar 13, 2012 | Marantz CDR510 2-Disc CD Recorder
What format audio files play on Marantz cd67? I've tried .m4a, .aiff and .mp3. The .mp3s are in a folder - might that make a difference?
Replace with a Philips VAM1202 Laser pick-up.
This is a revised version of the CDM12.1 and has a very good reliability
record.
If you replace with another CDM12.1, there's no telling when this
will also pack up as these have a very high failure rate.
Oct 02, 2010 | Marantz CD-67 SE CD Player
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
54 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
