Konica photocopier 7115 with error code (cof32)
Hi i have a konica photocopier 7115 with an error code (cof32), now before the machine displays the error code, the machine starts up fine and about 2 mins later a message comes up saying "machine trouble" and then the error code comes up, can any help please
thanks
Adam
I have konica 7115 its shown COF 37 pls i need ur help
Posted on Jul 19, 2012
    New Friend:
J2 eor
Posted on Aug 07, 2011
SOURCE:
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 22, 2017 | Konica Minolta Konica Bizhub 283 Copier,...
My konica minolta bizhub 163 is displaying an error Code COF32, please i need a solution for it thanks.
Here is a link to the factory support site, it is the best I can offer on this, please contact them. index
Oct 17, 2016 | Konica Minolta Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
Konica minolta b163 has this code cof32, how to take it out?
Hi
I have found your problem here:
Error Codes Konica Minolta bizhub 163 Code C0F32
and it says:-
Code:- C0F32
Description:- Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Remedy:- 1 Check to see if developer is available. 2 Check the ATDC Sensor connectors for proper connection and correct as necessary. 3 Change UN1. 4 Run ?gATDC Auto Adjust. 5 Change PWB-A. 6 Change PU1.
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Konica Minolta Office Equipment & Supplies
How can i solve error code C0F32 in konica miniolta 7118
Press [Utility] -> [Stop] -> [0] -> [0] -> [Stop] -> [0] -> [1]. Go to [Adjustment] --> [ ATDC Adj. ] [Start], wait for 2 mins. it will automatically stop then turn Off / On copier. If C0F32 appear replaced the ATDC sensor located under the developing unit then calibrate again.
Oct 16, 2014 | Konica Minolta Konica 7115 7118 Compatible...
I have Photocopy machine have error code cof32 in bizhub di 3510
have to have the drum and developer replaced
Apr 05, 2014 | Konica Minolta bizhub Office Equipment &...
Error code cof32
ATDC setting error - COF32, run F8 & use actual value, do not reduce setting value. open sie cover to reset.
Feb 14, 2011 | Konica Minolta DiALTA Di200 Copier
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Jun 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
MY KONICA 7115 COPIER HAD DISPLAYED ERROR C05 00 CAN YOU HELP ME
turn off the machine and hold down the STOP botton while turning on the power .hold for 5 seconds .
than should reset the code .if the code pressist that you have a bad thermester in the fusing unit.
good luck
May 01, 2010 | Xerox CopyCentre C118 Copier
Open Questions:
Computers & Internet Logo
1,330 people viewed this question
Ekse
Alun Cox
