Water leaking into drum?
The washing machine is washing and draining normally but when the machine is off the water is coming into the drum. It will drain when that setting is chosen but once finished the water appears again!
  • Anonymous Mar 31, 2014
    water is still in the drum washing is done
  • 30 Answers
Hi it sounds like you have a water valve staying open you will need to find out if it is the hot/cold then replace hope this helps
Posted on Mar 12, 2008
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
LG 1814CW washing machine leaking water
It may be time to replace that door seal again
May 07, 2014 | Washing Machines
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Water all over floor. Replaced broken door latch. Still leaking. removed front bottom panel. it looks like water is coming from the drum???
it sounds like a door seal problem ,its normal when wter is comming from drum most front loader fill by spraying water on drum,you may also want to check drain hose it could be kinked or pluged up,se what this does and clean filter if you can get to it.
Dec 16, 2009 | Washing Machines
2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Apr 19, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Water drips out of front door
There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
