RCA Model D61W20 - cable plug came out
The cable/antenna plug came out- can it be replaced? Is there a temporary solution ubtil we can replace?
Go into vcr then use rca inputs to tv . the cable sockets are usualy pretty easy to replace .take out old part and might even find replacement at local radio shack.
Posted on Mar 12, 2008
RCA D61W20 antenna/cable broke off
You have two real options here.
First any good shop can remove the board and repair/replace the fitting but it will not be cheap.
Figure 150 minimum for this on this set.
Second: If you have a cable or sat or other box for signal and it has AV jacks on the back---go from them to one of the inputs on the back of the set and BYPASS the tuner connection.
If you do not have a box but have an old VCR around (it does not have to work) you can connect the signal source to it and from its output (audio/video not the coax) route signal to the set.
Does this make sense or do you have questions?
sd tech
Oct 28, 2011 | RCA D61W20 61" Rear Projection Television
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Power supply sparks when tv is turned on
That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
May 08, 2009 | RCA D61W20 61" Rear Projection Television
61" RCA Projection TV Model #: d61w20
You could have shorted Yoke and if so you have to replace all 3 yokes another thing that can cause this is Capacitors on Deflection board cp150,cp114,cp120 If cp150 2200uf 16v is puffed up on top then it is bad ,so replace all 3 caps other 2 are 220uf 35v.
Jan 02, 2009 | RCA D61W20 61" Rear Projection Television
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
D61W20 RCA, Red Screen and then shuts down
sounds like the Red CRT (tube) has shorted. You can test by removing the RED crt circuit from the end of the RED tube and making sure it isnt touching anything try powering up the set. If it comes on and doesnt shut down the red tube is the problem and will need to be replaced . expensive part to replace the Red XRT will be over 300 and at least 2-3 hundred to have it installed unless you know someone who can replace it for you.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
