Question about Yamaha HTR-5650 Receiver
Htr-5650 2 channel only...no 5.1...HELP!
Having trouble acheiving 5.1 sound...I am stuck on if it is a connectivity issue or setup issue...I have downloaded the pdf of the owners manual and attempted to confirm that the setup is good...but this has not helped...the unit did have 5.1 connectivity, but now is not able...could I have connections wrong and it simply does not know to "auto" my channels? What are your thoughs? I am going crazy!
  • 1 more comment
  • gr8dane lady Apr 25, 2008
    no sound for tv, do have sound for tuner. probably an input problem but manual is not helpful. we selected cable-auto with 6ch surround sound. i dunno if this is the exact same model number, bought new 3 yrs ago now, i think.
  • Chuck 545 May 02, 2008
    Same problem -- main speakers okay, nothing from center or rears, no matter what the audio source. I think that I have set up everything correctly.
  • xmatkap May 20, 2008
    Same problem...No rear sound :(
  • 151 Answers
MAKE SHURE THAT THE OUT PUT SIGNAL FROM YOUR DVD PLAYER IS SET 2 BITSTREAM 2 GET DOLBY DIGITAL AND DTS FROM YOUR AMP.FROM SOURCES LIKE SET TOP BOXS AND OTHER "STEREO" SOURCES YOU WILL GET PROLOGIC2 ,BUT YOU MUST SET YOUR AMP 2 THIS MODE.
HOPE THIS HELPS.
CABLE GUY
Posted on May 20, 2008
    Sergeant:
  • 261 Answers
If you receive a stereo signal, 5.1 stereo should always be possible. Let me know if you have further problems. Good luck. GURU JAY
Posted on Mar 22, 2008
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
Yamaha HTR-6030. Using two optical cables for cable tv and xbox/wdtv-live box. On some cable channels and also on my xbox, no sound will play if I use it "straight". If I use "simulated...
Please don't panic and think that there is anything wrong with your Yamaha receiver. A lot of people are having this problem with set top box reception. Time lag / phase differences caused by satellite transmission can make your Receivers digital decoders go nuts !!!.The working principal is too complex to explain on this page. I have had clients call up and say on some channels only one speaker works in a 5.1 setup !!!!.You noticed DD and DTS signals are working fine.
Mar 12, 2011 | Yamaha HTR-6030 Receiver
I am installing yamaha 565 amplifire i can not heard soud of lead actor supportin actors voice is coming properly kindly help me as soon as possible
This would most likely be a failure of the center channel ort speaker. Did you set up your speaker complement according to the manual including the test tones and volume adjustments?
http://www.retrevo.com/support/Yamaha-HTR-5650-Receivers-manual/id/23165dj683/t/2/
Page 20-21
If you have more questions we need to know some details about your speakers and how they are connected.
Jan 18, 2011 | Yamaha HTR-5650 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
My right main channel does not work on my yamaha HTR 5650
Hello
If the amp is out of warrenty period, open it up and follow the path from the mute channel on the circuit board. You should see if the capasitors on that path is done(Blown). You can fix this yourself if you know how, otherwise take it to a repair shop will be a cheap fix.
Otherwize check the ic on that channel. Hope this an help you.
Best regards
Andrea
Nov 05, 2009 | Yamaha HTR-5640 Receiver
TV Audio out to HRT 5650 receiver
You may need to enable the fixed audio output line level from the TV. Some TV`s require you to enter the AUDIO menu/setup selection on the TV remote controller, and then enable the AUDIO OUTPUT Jacks, this will turn off the TV built in speakers and engage the audio RCA Jacks.
Feb 15, 2009 | Yamaha HTR-5650 Receiver
Yamaha - 5650/HTR-5640
Did you try going thru the setup portion of the owners manual? IF you need the manual you can get it online free. I realize sometimes people read the manuals and don't understand the technical jargon. Let me know if you need further assistance thur chat session and i can possibly step you thru it better in real time. Good luck Guru Jay
Feb 02, 2008 | Yamaha HTR-5650 Receiver
No sounds from rear speakers..... Yamaha HTR-5650
Select different modes on the remote or front panel and make sure all speaker that you have hooked up are showing on display. Are the Lt & Rt channels at least playing audio? If you want, i can step you thur some steps to try in live chat if you want today. Let me know as i have experience in this area! Sincerely Guru Jay
Jan 03, 2008 | Yamaha HTR-5650 Receiver
Yamaha HTR-5650 Receiver Logo
161 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
